DJI-Jamie
Flight distance : 112405 ft
aviscomi Posted at 2017-1-28 04:12
Jaimie,
The issue that I'm having in regards to selecting lenses is, "what's needed for balancing?' I've seen where 3 separate individuals are using the same lens (i.e. Olympus 45) and each have balanced it differently. Some w/hood, some w/o hood, some w/UV filter, some w/o....
In regards to the X5S, page 6 of the manual does have a chart as to what basic components are needed to balance:
https://dl.djicdn.com/downloads/ ... ser+manual+v1.2.pdf
The chart does not take ND, or other added filters into consideration. If you plan on using them, however, then you may need to get more creative like others have done to get the correct balance. |
