hallmark007
Flight distance : 10017858 ft
Sorry didn't see your HD link, just checked them, it is almost certain that bad interference connected with compass to bring your aircraft down
You did get a warning about interference at the start of your flight, yes it was a very quick just take care almost nonchalant warning.
You did take heed of this warning , one by flying very close in beginner mode LOS in what appeared to be a safe place to fly.
You got no bad compass warning or , move or calibrate warning, if you had got these warnings you would not have been able to take off, until you corrected this.
While flying your compass and gps seemed to be working perfectly together no conflict, until that one moment right at the end .
It looks like there must have been some interference in the area to cause aircraft to react the way it did, I don't know if it's possible to find out what it might have been..
I think you have some leeway here for a case to support your actions during your flight. I would point out to dji that everything you could have done you done, and they must be in someways complicit if not fully responsible for this, what I will now call an accident.
1/ you got a warning interference, You correctly followed this warning by being extra careful , flying in beginner mode, flying close, not flying to high, and for most of your flight you were in full control and AC and RC gps and compass all seemed to be working fine.
2/ when your AC spirals and goes down you had no warning and certainly no time to recover.
Good luck |
