Commodon
Flight distance : 347677 ft
dronist Posted at 2017-4-24 14:21
Put the drone in a cool place outside at night for 30 minutes or if you are in a warm area stick in the the fridge.
Take out, fire up DO NOT UPDATE, stay away from any metal etc., do the IMU on a 100% leveled surface. then shut/ restart and again DO NOT UPDATE, then do the AUTO Gimbal Calibration. Shut / restart and do the upgrade.
Never, never, never put a warm drone in the fridge! If you do this, it will lead to creating condensation inside the unit when you remove it from the fridge.
Instead, power the drone off, remove the battery and leave it sitting in the shade for thirty minutes if you're outside.
After the drone has cooled off, locate a flat, level surface, insert the battery, power it up and calibrate the IMU.
Note I strongly recommend using a level to ensure the surface is level. |
