Cetacean
Flight distance : 2528264 ft
Dobmatt Posted at 2017-5-3 13:32
Thank you for testing this way of piloting. Very interesting and promising results indeed. I assume you hold C1 or C2 button down while executing tight passage with Narrow Sensing assistance, right?
Aloha Dobmatt,
Actually, depending on if you are flying Mode 1 or Mode 2 (which stick is up), you should choose C1 or C2. That is because the forward and backward (left & right) stick should be opposite the Narrow Sensing C button. Pressing a C button while guiding the P4 Pro through a grove or jungle with the same hand is risky. You need all your attention on the forward and backward, left and right stick while looking at the sensor responses. I fly Mode 2 like most people so I choose C1 button as my Narrow Sensing button.
When I first tried Narrow Sensing, I had the selection on the C2 button and learned the hard way that I needed to reverse to the C1 button. It was very hard doing both. I actually made the change while in the air! Lucky the P4 Pro has High Capacity batteries.
Aloha and Drone On! |
