Battery flashing 1st LED, not charging.
123
203534 90 2017-5-17
sh123
Indonesia
   keep  flashing  untill no power   ,cannot recharging,
2022-3-16
sh123 Posted at 3-16 19:47
[view_image]   keep  flashing  untill no power   ,cannot recharging,
Sorry to know about the issue. May I confirm that if the indicator will flash when charging? If possible, please test with another adapter. If the issue still exists, you can start a case through the link below and send it back for further diagnosis as long as the battery is within the warranty period. http://www.dji.com/support
2022-3-16
djiuser_t5OKNMP0jd0G
I put my battery to charge the led fathers away from the power button keeps blinking rapidly like 16-17 blinks then turns off then does it again every 6 seconds. And doesn’t seems to be charging. What do I do? I have the mavic pro
2022-10-5
DJI Wanda
djiuser_t5OKNMP0jd0G Posted at 10-5 21:45
Hello, there. Sorry for your inconvenience. May we know did all the indicator lights blink together or in succession? Did you try to charge other batteries with the same charger? Did the charger work normally?
2022-10-6
Gilberto Fonsec
DJI Phantom 4 Advanced with the same issue
Led 1 flashes green 16 times (3per sec) no lights for 7 seconds and the loop starts again and again.
As I tried many times the battery now show 0% on DJI GO 4 but it still blinks in green colour.
Battery volts are 3.58v 3.56v 3.59v 3.59v.
Total Voltage is 13.7v and the temperature is +23 degrees celcius.
I have no Idea why it`s behaving like this. Any news about it?
2023-3-30
Gilberto Fonsec Posted at 3-30 08:59
Hi there, we are sorry to tell you that the battery may be malfunctioning in this case. We recommend you purchase a new battery for use if it's out of warranty. You can also contact our support team through the link below for further assistance. http://www.dji.com/support
2023-3-30
sherkoabosh_S
Sweden
Hello. I have the same problem with my battery for dji mavic pro. When in the charger, LED 4 is blinking fast 15 times and then stops blinking for some seconds and then starts again. What can I do?
2023-5-17
fans0e0c027a
Flight distance : 163422 ft
Ok so I bought a Mavic Air  with 3 batteries, when I received drone I opened box and checked all 3 batteries to find out they were all dead. I put the 1st one on the charger for 2 hours & nothing, Same with 2nd & 3rd. When I push the battery indicator light 1 green light shows up if I click it 2 times all 4 lights blink & then they stop blinking. It only blinks when connected to the charger. If I take battery off charger it won’t do anything….. What am I doing wrong to be able to charge these batteries? Any help is appreciated.
2023-12-19
DJI Wanda
fans0e0c027a Posted at 12-19 00:04
Hello, there. May I confirm if all four LED lights blink three times and then go off?
Do all three batteries act the same?
2023-12-19
djiuser_TJgshYfDW8lb
I think I find the solution. Mine had been doing the same thing. All I did was take the battery out of the drone and let it cool off for a few minutes. Then once I put it back in it charged as normal.
I think the issue is an overheated battery. It’s not broken.
Cheers
4-1 18:29
DJI Susan
djiuser_TJgshYfDW8lb Posted at 4-1 18:29
Hello. We're glad your issue has been resolved. If you have any further questions or concerns, please do not hesitate to contact our support team.
4-1 18:39
123
