Compass Calibration
12
4275 43 2017-5-30
hallmark007
Flight distance : 9827923 ft
Ex Machina Posted at 2017-6-3 16:39
Then why does it go away?
Another question might be why it's there at all if it's not needed -- what's the purpose of allowing calibration when the system hasn't detected a need for calibration?
Although I've never seen it I think it lights up red to calibrate and it won't say normal , this box is on mine I think every time I turn on,
If your compass needs calibration there is a warning where overall status is,  I can see where it is easy to get confused when you see this box.
There is also a warning where ready to go gps if your in magnetic interference area and need to move or calibrate.
2017-6-3
hallmark007
I presume if in overall status it tells you , you have compass problem you can click on button to calibrate.
2017-6-3
Ex Machina
Flight distance : 1806362 ft
hallmark007 Posted at 2017-6-3 17:14
That's why it's there, for sure, but why does it go away after performing a calibration? You'd think if the interface designer/developer decided to just show the calibration button all the time, it would show all the time. If it had shown all the time, I would eventually have noticed the "Normal" designation next to it. ;)
I do QA for web and apps interfaces, so this kind of inconsistency irks me.
Anyway, thanks all for bearing with me, much appreciated.
2017-6-3
hallmark007
Ex Machina Posted at 2017-6-3 17:27
I agree calibrate button should only appear and should be in red when there is a problem, because it is very confusing.
2017-6-4
12
