Antonio76
Flight distance : 144403 ft
Denmark
Lakeluvr Posted at 2017-6-15 08:11
As I understand SD cards, you are supposed to be able to push down on them to release them. I've tried that without success. To connect the aircraft to a computer do I use the mini USB port on the device?
Why the device? You connect the Aircraft to the computer via the USB cable (mini USB on the drone, near to the SB card, to USB on the computer), even if you have a P4P+ (SB Card in the remote control of the P4P4+ has nothing to do with your images or full resolution videos) See the manual, page 44/45. But I think you are not pushing the card (in the aircraft!) correctly, you need to press on the edge of the card with your nail. |
