Donnie *
Flight distance : 3636782 ft
Check the VPS sensor , see if it is dirty or if the wires are loose from the VPS to the Aircraft . Clean the lens with soft cloth and blow out ( gently ) the mesh covered sensors .
It should ( the landing gear ) lower only once if it is the VPS sensor , if it does it more than once than look at the RC transmitter switch ( for the gear ) , see if it is faulty .
donnie
