DJI Phantom 2 Vision Plus Assistant and Dead Gimbal
1721 7 2017-6-16
HertsFlyer
Just bought a 2nd Hand Vision plus to train with before I get a P4.
The drone was advertised as working and tested, the camera works but this Gimbal has failed since a firmware update.
I have read loads of posts about dead gimbals and cameras, the ribbon looks undamaged and the drone is spotless.
I took the cover off and the screw lock clue was still intact so looks like it was the first time it was take off.
I have completed a master reset and loaded the new software, the gimbal still doesnt move.
One thing I have noticed, is I have download the latest version of the assistant software 3.8 from the P2 vision plus page on the DJi for windows.
When I load the assistant the top title bar says Phantom 2, Not Phantom 2 Vison plus? the drone select tab does not have the vision2 listed?
Any ideas please?
2017-6-16
Mark The Droner
Flight distance : 2917 ft
My program is called DJI Phantom 2 Vision Assistant. ver 3.8  It works for both my Vision and my Vision Plus.  But the exe file itself is called phantom2.exe.  And yeah, after you go to run the program, it says Phantom 2 everywhere.  So it appears you have the correct program.
2017-6-16
HertsFlyer
Mark The Droner Posted at 2017-6-16 08:38
I think I better send it for a service to make sure its all ok, Not many dji approved repairs near me in the UK
2017-6-16
Harbourside
Flight distance : 6467 ft
The top bar should say Vision + as my screen shots in the other thread you commented on.
In the Vision app what firmware have you for the Phantom / Camera / app ?
Is the PT2 Assistant working, other than saying its a basic Phantom 2 ?
2017-6-16
HertsFlyer
Harbourside Posted at 2017-6-16 12:52
The Assistant loads ok, the top title says Phantom 2
It allows the calibrations of the control etc and updates all the other firmware ok.
But theres nothing for the gimbal or camera, under the updates the gimbal's not listed.
The camera has the green flashing light, it takes an update via the sd card,  as the file gets renamed.
Could it be the camera/Gimbal has a fault and its not detecting it? I was told it was only after an update?
2017-6-17
HertsFlyer
HertsFlyer Posted at 2017-6-17 03:43
https://www.facebook.com/photo.php?fbid=10154926561147054&set=pb.608552053.-2207520000.1497700515.&type=3&theater
2017-6-17
Harbourside
I guess that as its not detecting the ZEN IMU that's why the assistant shows a basic Phantom 2.
Unfortunately I gave my V+ to my brother-in-law for Christmas, so I cant do any tests.
Hopefully someone will be able to help you on here.
Good luck...
2017-6-17
HertsFlyer
Harbourside Posted at 2017-6-17 06:36
Thanks Appreciate the help
2017-6-17
