Inspire X5R Slave Controller + Gimbal Problem
1360 6 2017-6-17
fansb3514154
Hello everyone,
i bought a Inspire X5R and all installations are Done. Inclusive new FW update..
So i still have one issue with the control of gimbal with my slave controller.
I clicked on "Control Gimbal" and confirmed on the master controller. Then I have access to the gimbal.
In the remote control settings, I can define the directions, but the gimbal does not move.
Please take a look to my video:
If i turn the slave Controller on, it make *peep* two times. is tha correct?
Kind Reagrds,
Ricardo
2017-6-17
DJI-Jamie
Flight distance : 112405 ft
If you try to make the master RC the slave, do you get the same effect?
2017-6-17
fansb3514154
DJI-Jamie Posted at 2017-6-17 21:48
Do you mean to convert the Master RC to the slave and the slave to the master Rc?
2017-6-18
fansb3514154 Posted at 2017-6-18 13:05
That's right, please switch the Master and slave RC to have a try.
2017-6-19
Donnie *
Flight distance : 3636782 ft
This could be one of about three things :
1- Do you have the Master camera control camera set to the FPV mode ?  Make sure it is set to the "FOLLOW"
2- Next go the Gimbal settings ( configuration1- 2-3  is under the Advanced tab ) and make sure none are set to to low a value , ( gimbal Pitch- Yaw )  the Camera will not move if the value is set to ZERO or barley move if below say a setting of FIVE , for testing I would write down the current settings and then "Reset"  them and re test , you may have the settings set to low .
The last thing to check is that you dont have the Master RC set to "Coach Mode " do you ?  If so be sure to disable it . ( this option is on "remote control settings of go app ). coach mode allows full contrtol of the Ac from the Slae Remote .
I think the problem is one of the above .
Dont swap the Master to the Slave till you try this .
You vido does not give alot of ionformation but I think I know what you are referring to .
LET US KNOW !
donnie
2017-6-19
DJI-Jamie
Were you able to get it sorted?
2017-6-19
mancuso_inc
Flight distance : 39708 ft
Donnie * Posted at 2017-6-19 05:42
not sure if this helps anyone, but I was having a similar issue where my slave remote wasn't panning the camera, only tilting. I noticed in the app that the camera was set to FPV and not FOLLOW. After changing, the camera worked again
2017-12-29
