parsonsphoto
I am steaming mad!
Just spent thousands on Osmo Pro kit. Opened up and followed the instructions for setup, firmware update and the system just sits there limp and not functioning. For hours I tried everything listed on the internet and these forums. Seems like a number of people have had this same problem. DJI, if you expect people to pay thousands for a product it better damn well work out of the box. I can understanding a deffective item here or there, but this appears to be a frequent problem. The big issue here is that I need this camera for a shoot in 1 week and at the speed I have been getting responses from DJI for anything I think I am screwed for that. Thanks DJI!
I am not sure where to go from here. Anyone please advise!
Here are the things I have tried.
-initail firmware download (appeard sucessful, but system not functioning)
-subsquent firmware re-attempts (same bad results)
-downloaded prior version and no success on the firmware update with the camera
-tried using a different card
-held trigger, shoot and record buttons in an attempt to reset (not sure if that is for the x3 setup)
-tried crossing my fingers (least effective)
Here are the text details from the cards after the last 2 firmware update attempts:
========== 2014.01.01 00:00:09 remo-con disconnect======
Packet: OSMO_FC550_FW_V01.04.00.70.bin
Upgrading ...
FOCUS NOT CONNECT.
FOCUS NOT CONNECT.
Result: Success.
FOCUS NOT CONNECT.
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the device.
FOCUS NOT CONNECT.
Result: Abort.
========== 2014.01.01 00:00:11 remo-con disconnect======
FOCUS NOT CONNECT.
Result: Abort.
FOCUS NOT CONNECT.
Result: Abort.
========== 2017.06.16 23:01:53 =====================
Result: Corrupted.
Firmware bin file is corrupted, download it again from the DJI offical website.
========== 2014.01.01 00:00:08 remo-con disconnect======
FOCUS NOT CONNECT.
Result: Abort.
FOCUS NOT CONNECT.
Result: Abort.
FOCUS NOT CONNECT.
Result: Abort.
FOCUS NOT CONNECT.
Result: Abort.
Packet: OSMO_FC550_FW_V01.03.00.40.bin
FOCUS NOT CONNECT.
Upgrading ...
FOCUS NOT CONNECT.
FOCUS NOT CONNECT.
Result: Success.
FOCUS NOT CONNECT.
Result: Abort.
========== 2014.01.01 00:00:06 remo-con disconnect======
FOCUS NOT CONNECT.
Result: Abort.
FOCUS NOT CONNECT.
Result: Abort.
and
Upgrading ...
FOCUS NOT CONNECT.
FOCUS NOT CONNECT.
Result: Success.
FOCUS NOT CONNECT.
Result: Abort.
FOCUS NOT CONNECT.
Result: Abort.
FOCUS NOT CONNECT.
Result: Abort.
FOCUS NOT CONNECT.
Result: Abort.
Result: Corrupted.
FOCUS NOT CONNECT.
Result: Abort.
FOCUS NOT CONNECT.
Result: Abort.
FOCUS NOT CONNECT.
Result: Abort.
FOCUS NOT CONNECT.
Result: Abort.
FOCUS NOT CONNECT.
Upgrading ...
FOCUS NOT CONNECT.
FOCUS NOT CONNECT.
Result: Success.
FOCUS NOT CONNECT.
Result: Abort.
FOCUS NOT CONNECT.
Result: Abort.
FOCUS NOT CONNECT.
Result: Abort.
FOCUS NOT CONNECT.
Upgrading ...
FOCUS NOT CONNECT.
FOCUS NOT CONNECT.
Result: Success.
FOCUS NOT CONNECT.
Result: Abort.
========== 2014.01.01 00:00:10 remo-con disconnect======
FOCUS NOT CONNECT.
Result: Abort.
FOCUS NOT CONNECT.
Result: Abort.
========== 2017.06.17 01:17:02 =====================
FOCUS NOT CONNECT.
Result: Abort.
========== 2017.06.17 01:19:25 =====================
FOCUS NOT CONNECT.
Result: Abort.
========== 2017.06.17 01:20:46 =====================
FOCUS NOT CONNECT.
Result: Abort.
FOCUS NOT CONNECT.
Result: Abort.
========== 2017.06.17 01:24:25 =====================
