jimmybbq
Nees Posted at 2017-6-19 04:19
Post pictures, that will help what you are doing wrong. If you are shooting against the sun, it will be a white sky, with the sun, it will be blue.
I shoot in 2.7k @ 30 fps
Ideally you want ISO 100 or 200
I usually pick my auto white balance i.e. Sunny, Cloudy etc. You can leave it in Auto, but your picture may change during the course of a video.
I shoot in D-Log, but I color-correct in software because this leaves a very flat picture.
You want your shutter speed to be double your "frames per second"
Put your mavic in the sky and identify how much it's over or under exposed.. example +2.0
Download the polarpro app and plug your numbers in there, it will tell you which filter to use to get your shutter speed down.
You will probably need, at a minimum, ND8, ND16 and circular polarizer.
Download Davinci Resolve (it's free), learn it, use it.
Polarizer filter - Hold the filter in a way you can look through it, rotate it, identifying the orientation that yields the best greens and blues, make sure you put it on the camera lens in the same orientation.
ND filters - Just stick them on your lens |
