Fantick
Flight distance : 89616 ft
Lithuania
[size=1.3em]Osmo+ does not working. The product was activated on 04.2017. The malfunction is: the gimbal does not work. After the power on initialization is started for 1 second, then the camera hangs with head down and uncontrolled no more. The message appears on the screen: unlock the gimbal but it is not locked. The camera can be used to shoot photos and video. When restarting with the trigger and the buttons photo + power is the same: the gimbal starts to move then helplessly hangs with head down a beeping is that the gimbal is blocked and the message that it needs to be unlocked. The last firmware is in the camera. The downgrading the firmware to the previous one does not make any changes.
========== 2017.06.19 15:19:56 remo-con disconnect======
Packet: OSMO_FC350Z_FW_V01.05.00.90.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the device.
========== 2017.06.19 15:38:28 remo-con disconnect======
Packet: OSMO_FC350Z_FW_V01.04.00.70.bin
Upgrading ...
Result: Success.
========== 2017.06.19 15:52:17 remo-con disconnect======
Result: Abort.
========== 2017.06.19 15:53:02 remo-con disconnect======
Result: Abort.
========== 2017.06.19 15:53:30 remo-con disconnect======
Result: Abort.
========== 2017.06.19 15:56:53 remo-con disconnect======
Upgrading ...
Result: Success.
========== 2017.06.19 16:01:43 remo-con disconnect======
========== 2017.06.19 16:02:09 remo-con disconnect======
Result: Abort.
I am asking for the help in solving this problem. Camera-09RDEA19000443. MACHINDER: 6060 1F406F37. 06NKEA1 20B0314
[size=1.3em]
_________________
I give as good as I get
