While flying, the P4P lost connection and started RTH. As it neared, I was able to cancel RTH and land manually. I noticed that I had no video feed. As the drone got close, I noticed the gimbal/camera was dangling loosely. I landed safely, and waited a few minutes to let everything cool down. I powered off everything including my phone. Next, I powered everything back on to see if I still had a problem. I did. These were the problems:
(1) Gimbal makes an abnormal, loud vibrating/buzzing noise (kind of like a vibrating phone on a table). It may go away for a second if you gently touch it or tilt the aircraft, but it quickly returns.
(2) no video signal
(3) menu indicated “gimbal disconnected”
Everything else seemed to function. The gimbal did go through its warm up movements, and autoleveled appropriately, just without signal to RC/phone. I tried removing the SD card, and power cycled everything several times. All 3 problems persisted. I was sure the drone would need to go in for repair.
Here is the twist! The next day I checked everything one last time, before calling customer care. And, voila! No problems. Everything functioned normally, gimbal and all. BUT, I happened to grab a DIFFERENT battery.
So, I have 3 batteries. I alternated between each battery 4 different times (12 trials). The 3 problems (noise, no signal, gimbal disconnected) occur 100% of the time with the “bad” battery, but never with the other 2 batteries.
How in the world could a battery be doing this? I need some advice before calling customer care.
Thank you all!
