Dear Pilots, I have one Mavic Pro and I’m a beginner flyer. I will tell you my situation asking some advice. I had the hardware problem with the second compass; the same, till end of 2016, were about 3 or 4 cases related; and DJI assumed the hardware problem changing the failed ones to new. But I am from Brazil, and here we have so many difficulties on technical services and guarantees. So, I decided to forget about this problem. I am flying normally. In the map, I see the triangle and the orientation is correct. I even flight above sight-seeing one time, by my own risk, just to see if I could bring the Mavic back and it was ok. Sometimes, I am notified by DGI GO4 that I’ve missed my compass orientation. I says that I need to move the aircraft and doing this it considers ok. So, I am here to ask you opinion about the problem and if you consider I need to try to solve it with DJI. Thanks for your attention,
DocAraxá
