Changing RTH height in flight
2101 11 2017-6-22
monstermash
Flight distance : 26240 ft
Is it possible to  change the RTH height during flight.  Let's say I thought 30 m was high enough and then I need to change to 50m to ensure that I can clear the trees to safely land after take off, is it possible, tks.
2017-6-22
Bracco
Flight distance : 244856 ft
I am not sure, but i think that it's possibile. Try to take off and then go to the rth height option. I set my rth height to 80 meters and this values cover pretty much every situation
2017-6-22
DroninAdventure
Flight distance : 399590 ft
From my understanding you should be able to too through the menu, like you usually would, and change it to whatever you desire. Im lucky. Florida is superrr flat. 30 meters usually clears everything haha!
2017-6-22
Uncle Stumpy
Flight distance : 140315 ft
Avoid the headache and just set it higher before you even fly.
I have mine set for 100 feet because where I live there are no buildings or trees that high.
If you do, set it higher before you even fly.
In answer to your question, I don't know!
2017-6-23
DJI Thor
Flight distance : 13602 ft
It can be changed during flight. But, I would also like to set it higher before I fly it, like Uncle Stumpy mentioned, avoid the headache, Haha.
2017-6-23
Labroides
Flight distance : 9991457 ft
Yes .. it's possible.
You also have the ability to use your left joystick during RTH to vary your altitude as well.
2017-6-23
SargeAF
DroninAdventure Posted at 2017-6-22 21:58
But palm trees which can reach heights over 100 feet
2017-6-23
SargeAF
I run into the same problem here, thought 100 feet would be higher than the trees around me and found some that are a little taller than that, so what i have done is look around the area i fly in and find what i believe to be the tallest object then fly my drone next to it, with the camera aimed at it, up to the height at which i can see over that object with the camera tilted slightly down, hover check your height on the app, set your RTH accordingly
2017-6-23
monstermash
Thanks everyone, I guess this wasn't a silly question after all, lol.
2017-6-24
monstermash
tks man, appreciate it
2017-7-26
Sasquad
Flight distance : 319245 ft
Yes you can alter it during flight, no problem at all. I set mine to 30 meters, and during flight I changed it to 50 meters. When I activated RTH. The altitude read 163 feet. Very close to 50 meters.
2017-7-27
fanse66a30c8
Flight distance : 18251 ft
Yes, just don't go over the heighth you have set for your maximum altitude. I just leave my RTH altitude at 60 m and forget.
2017-7-27
