unsync video and audio stream with adobe premiere
1156 1 2017-6-24
HKpotgDDxuZ1
Japan
Hi, there.
(I'm not good at English.)
I recorded the video with front-camera of iPhone 6 plus and DJI GO v3.1.11 on iOS 10.3.2.
(video settings: 1080/30p)
Then if I open the file with Adobe Premiere Pro 11.1.2, the video and audio stream will be out of sync.
The video is a little faster than the audio. I try change duration of the video stream to 99.4%, I seem to be sync.
I examine the information of the file that using ffmpeg, it was displayed as follows
> Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, smpte170m/bt709/bt709), 1280x720, 8393 kb/s, 29.80 fps, 29.97 tbr, 600 tbn, 1200 tbc (default)
... 29.80fps?
I try open the file with other app ( example, VLC Media Player ) , it play speed is no probrem. Synced.
And I try recoding with other app ( example, Filmic Pro ), then it is no probrem.
There is no one in the same situation?
2017-6-24
JamCot
Flight distance : 163878 ft
Hi, I have just discovered the same issue with audio sync. iPhone 6S with DJI GO 3.1.23(2812), iOS 11.2.2. Premiere Pro V12.
2018-1-15
