Errors during flight with A3, LB2 and x3 on S1000
5013 37 2017-7-1
Adamphillip
hey guys as the title says I've been getting errors with my set up, they started thursday after I upgraded all the firmware
errors as follows
insufficent hover propulsion. add load to aircraft.
tilt angle error. adjust the aircraft center of gravit...
aircraft shaking error. take effective messures to reduce shaking....
we've fiddled with all the gain settings and nothing is stopping the errors
2017-7-1
fans08ac15b2
Flight distance : 791020 ft
Israel
Hi Adam,
Thanks for sharing!
We're seeing exactly the same 3 errors, using a Tarot frame with the same A3 flight controller + LB setup.
It started the past day or two. As far as I can tell we didn't change the firmware, but maybe it got upgraded automatically (checking this now). The A3 is currently on firmware version 1.7.0.5. (We didn't upgrade yet to the new 1.7.1.5).
Let me know if you find anything or any additional things I can check from our side.
Best, Amit.
2017-7-2
info.christophm
I have the same issues ...
2017-7-2
Juan carlos3
Flight distance : 31768 ft
I have the same issues and regroup in someone tells me that the works it well
2017-7-2
jackwrangham
Flight distance : 917057 ft
Same issues here with N3 and A3, custom quadcopter. It seems to be after a GO App update. Systems unchanged apart from that.
DJI any feedback?
2017-7-2
TaylorPilot
Just flew an a3 Pro lightbridge 2 setup on an s900 and got the same thing.  I don't have a gimbal on it yet, but have added ballast to the front to bring the cg inline.  I tried updating the ground unit through my ipad, but it never gets below 0% and errors out....the thing flies, and seems to be hovering fairly well.  Only issue besides the errors is that when I go to yaw, it turns around a point about 3 feet to the left of the drone.
2017-7-2
Juan carlos3
I thought that was the only one with this problem
https://www.dropbox.com/s/kpo39ks6rs...%2013.mov?dl=0
2017-7-2
TaylorPilot
Mine is a much wider path than that....probably 6-8 feet to diameter....What drone is that you are running?
2017-7-2
Juan carlos3
YAW diameter is 10-12 feet, then returns to its position
https://www.rcgroups.com/forums/ ... ad%2A%2A%2A/page139
2017-7-2
Juan carlos3
And DJI says nothing
2017-7-2
TaylorPilot
Well, I am taking mine to a pro to get it tuned next week, hopefully they will be able to get it figured out, and if they do, I will let you know what they say.
2017-7-2
TaylorPilot
There seems to be several threads about this issue, you just need to search "yaw drift".  Maybe not specific to your drone, or that flight controller.  It seems to span from IMU issues.  Either calibration, or placement.  Have you done an IMU calibration?
2017-7-2
Adamphillip
well I fixed it, it's an error with the IOS app and was able to operate without errors by using my android device
2017-7-3
TaylorPilot
Cool, I have been trying it with an iPad.  I can't seem to get it to even recognize the A3 with my Note 5.....
2017-7-3
Adamphillip
TaylorPilot Posted at 2017-7-3 15:55
I just used my note 4 phone
2017-7-4
cenk_d
Flight distance : 137956 ft
Turkey
Adamphillip Posted at 2017-7-4 01:50
I am getting the same 3 errors on my 1.7.0.0  firmware N3 with the latest ios and android app. Before that there were no errors on the same setup. Could i learn with what version of android app your issue was resolved,  Adam?
2017-7-4
Hazardpro1
Im getting the same errors on the latest version of the App too.
insufficient hover propulsion. add load to aircraft.
aircraft shaking error. take effective measures to reduce shaking....
N3 (1.7.0.0), LB2 (latest firmware), latest version of GO app (on ipad mini).
Come on DJI need you to at least address the issue.
H
2017-7-5
Teles3
Portugal
Same thing with N3 + LB2 + X3 with Hexacopter
I was flying on a mountain with 60kph winds I was worried.
I updated the N3 crashed my drone (the updated changed the configuration from I to X)
2017-7-5
Hazardpro1
Teles3 Posted at 2017-7-5 03:26
Teles3 - When you update N3 firmware you always need to reconfigure your settings.
But this issues seems to be related to the GO app, not flight controller.
Can anyone confirm if its safe to fly with these 'false' errors?
H
2017-7-5
Hazardpro1
Also is this only effecting people on Apply devices?
Anyone tried with Android?
H
2017-7-5
cenk_d
Turkey
Hazardpro1 Posted at 2017-7-5 03:48
Same errors with the latest android update.
2017-7-5
TaylorPilot
4 Days, and still not a single word from a DJI Rep.....On THEIR Forum!!!!
2017-7-5
Juan carlos3
It is the policy of DJI
We break and they corrected (Beta tester)
2017-7-5
fansc07acdb1
Flight distance : 3162323 ft
Same problem here.
I have got some error messages using A3 and RTK on an Octo flat 8 with LB2. I have had this craft operating for about 4 months and it's been perfect. I am flying a Movi with Sony A7.
1. 'Tilt Angle error adjust the aircraft gravity to the geometric center of aircraft'
2. 'Insufficient Hover propulsion, Add load to aircraft'
3. 'IMU backup error, stop motors and check IMU redundancy'
After getting first two error messages I checked everything COG, props, gimbal attachment etc. Couldn't find any issues. Craft was flying perfectly at the time of first two error messages. Next day I tested again and got same error messages. After more checks the following day I tested it and got error 3 at which point the craft became almost uncontrollable. Managed to get it on the ground safely.
2017-7-5
fansc07acdb1
Hazardpro1 Posted at 2017-7-5 03:34
I wouldn't fly it with these issues. I flew mine for a short period testing to try and solve the issue. It then suddenly tilted 45 degrees and took off (away from me fortunately) very fast then stopped and ascended rapidly. Then it would hover for a few moments and repeat. This happened a number of times until I got it on the ground safely.
2017-7-5
fansc07acdb1
This is DJI response to my emails
we have known the issue, which is false alarm and we will fix it in the next version app.
Now you can use the method below:
If you can find V3.1.13 app for iOS, you can use it. Or you can find an Android device to use. Thanks.
Thanks for choosing DJI. Have a nice day!
Best Regards,
Amos
2017-7-6
LennyV
I am also experiencing these messages, I had not update yet so I'm not sure it is firmware up issue.
2017-7-17
Adamphillip
The problem I've had and this thread refers to has been solved by just switching to android
2017-7-18
ClarksonCote
Flight distance : 52936 ft
I have the same three issues.  Unfortunately, I don't have the luxury of switching to Android, as I only have an iOS device available.  Has anyone tried downgrading to an earlier DJI Go App version on iOS to see if that fixes things?
2017-7-19
ClarksonCote
ClarksonCote Posted at 2017-7-19 06:12
For iOS, the solution for me was to revert to an iCloud backup from a couple weeks prior.  That let me regain access to the prior version of DJI Go.  There are also other methods for downgrading apps if you search online.  Hopefully DJI has an App fix soon, sigh.
2017-7-19
Hazardpro1
Any update when this will be fixed DJI?
2017-7-24
Hazardpro1
I see a new version of the App was released on the 8th - can anyone confirm if this has fixed the issue?
Thanks
H
2017-8-10
Juan carlos3
I think that the problem is in the Assistant not A3
Assistant 2 were errors,but the A3 does not fly well
2017-8-18
Hazardpro1
We had been getting these errors on the N2. But its a DJI GO app firmware issues I believe not Assistant error..
The Latest firmware seems to have resolved the following errors:
However we are now (still) seeing this error on the latest version of the firmware:
tilt angle error. adjust the aircraft center of gravity...
None of the errors were apparent on version 1.1.10.2 and older
Id very much like to here from other users in this post to see if they are still getting the original errors on the latest firmware?
H
2017-9-7
Snakehaihai
Singapore
I also have this error. When i fly uav throttle up and pitch back autonomously and crash down.  in go app, this error pops up insufficient hover propulsion. any 1 have good solution to this?
2017-9-19
DJI-Mark
I am sorry to read on frustration on the recent updates. As a suggestion, please refer to the Assistant Software and try to re calibrate on the software. As it was stated that the fix is in the next firmware, you would want to keep an eye out for any updates and go from there.
2017-9-20
fansf6551702
Flight distance : 371 ft
Philippines
DJI-Mark Posted at 2017-9-20 08:39
Having this issue, is this resolve already?
2018-3-19
Paterik
fansf6551702 Posted at 2018-3-19 21:39
Obviously not! DJI you told us to keep our eyes open on september 20th 2017. You promised a new firmware with fix... Where is this firmware? How long do I need to keep my eyes open?
2018-5-16
