Dronie quickshot for Spark not gaining altitude
2364 25 2017-7-3
fans5f334c6d
Flight distance : 153566 ft
Dronie was going to be my favourite quickshot using my Spark, however after trying it a few times I noticed that it flew backwards without gaining any altitude. A quick look around revealed there were a few others having the same issue.
Has anyone found a fix for this?
2017-7-3
Blackforce
Flight distance : 33140 ft
I tried it out at the weekend. All the times it never gained height. just went straight back. id be interested to find out a fix
2017-7-3
Tony Q
Flight distance : 196870 ft
same happens to me
2017-7-3
DJI Natalia
Flight distance : 318 ft
Hi All, would you please export the flight log and data from black box so we can get it analyzed?
Please download the latest Assistant 2 from DJI official Spark website, install it, then connect the drone to PC, run Assistant 2, you can get the file step by step, upload it to Dropbox and post the link here, thanks.
Firstly, click on "Black Box", save it to local.
Then click on "Data Upload"--"Confirm", choose the log which showing the situation for that moment, and save it to local.
2017-7-5
J.G
Flight distance : 172562 ft
Same problem here using iPhone 6s and RC.
2017-7-13
pingywon13
Flight distance : 63724 ft
Iphone 7+ and RC and the same problem...this is documented all over this forum DJI. Please do not pretend like it is an isolated issue.
2017-7-13
Interloper
Flight distance : 251824 ft
I'm really surprised at the length of time it has taken for this to be resolved. A massive issue that has prevented the USP being part of the experience. Thought DJI would have corrected this by now.
2017-7-13
Cravenfan
Flight distance : 125256 ft
pingywon13 Posted at 2017-7-13 07:17
Agree, same issue for all of us, it would appear.  Glides back, doesn't gain any altitude.  Needs to be fixed in a firmware update, IMO.
Take any Spark off the shelf and test it...helix mode still goofy also, doesn't circle around close enough, etc.  Just sift through the dozens of posts on here...
2017-7-13
pingywon13
DJI Natalia Posted at 2017-7-5 03:41
If I knew I was going to be a DJI Spark Beta Tester I would have asked for a discount on the product.
I paid full price. Make it do 100% of what you have advertised it could do. Its that simple.
If you wanna offer me a partial refund - than sure Ill upload all the flight data you want. Heck I'll even go run tests for you, but short of that. No.
2017-7-13
J.G
The lack of response from DJI annoys me.
2017-7-13
CliffordL
Flight distance : 294619 ft
YES!  What they said!
2017-7-13
CliffordL
Exact same issue with iphone 7+ and RC.  Helix also goes 1/4 circle then drifts off into space
2017-7-13
CliffordL
pingywon13 Posted at 2017-7-13 09:32
nice - I like this guy.
Could not agree more.  Same issues with iPhone 7+ and RC.  Flat dronie and half-moon helix
Get it fixed.  My guess is that they all are doing it.
2017-7-13
pingywon13
CliffordL Posted at 2017-7-13 12:46
why thank you sir. I mean yes the spark is a cheaper "pro" drone. I have much more expensive ones..but the point is it is not like we spent $40 on this thing. we paid good money for a feature set that is 1/2 baked. Asking us for flight logs and stuff is just a stall tactic and a waste of time...
2017-7-13
CliffordL
This looks like a common problem.  Is there a fix in the works for the software?  I have the exact same issue with iphone 7+ and RC also without RC.  Dronie goes flat backwards with zero elevation.  Helix begins slow 1/4 circle with minimal rise and then drifts backwards in straight line after a few seconds.
Circle and Rocket work fine.
thanks
clf
2017-7-13
nucmanchh
Mine as well doesn't gain altitude - just flies backward
2017-7-13
DJI Natalia
Hi All.
I feel very sorry for any inconvenience caused, for the situation you reported that it does not gain altitude in Dronie mode, we have checked all the data you provided.
Actually speaking, it does work, we do suggest you to takeoff the drone and fly it at least 2 meters above the ground then enter to Dronie mode.
Besides, it will be optimized with the next firmware version.
Truly appreciate your patience!
2017-7-13
J.G
Mexico
DJI Natalia Posted at 2017-7-13 18:56
Hi All.
Are you kidding right?
I dont think everyone of us are trying helix or dronie in the incorrect way, this is a software issue.
2017-7-13
CliffordL
Hi All.
I have personally tried this method and the same situation occurs.  This is a software/firmware issue.
2017-7-14
pingywon13
Hi All.
You are kidding right? Take responsibility. Own up to the short coming and tell us the fix is on the way...dont cop out and tell us we are all idiots. Its really not that hard
2017-7-14
DJI Natalia
The situation you feedback has been reported to engineers, it will be optimized with the next firmware version, appreciate your patience!
2017-7-15
fans2046fc7b
I tried about 8 times now with different conditions: Change initial height, change distance from me etc. However, it doesn't gain altitude - just flies backward.
I updated the newest firmware which seemingly released today (July 26). I tried with new firmware but no improvement.
Shouldn't this be a simple software change? Please fix this ASAP DJI!
2017-7-26
Gscann
Flight distance : 47552 ft
Is anyone else still having this issue?
2017-7-27
fansfa9c1c91
Flight distance : 197 ft
I still have issue with dronie. I commented in another thread.
https://forum.dji.com/thread-106309-1-1.html
2017-7-27
fans0d5dbb98
Flight distance : 302 ft
I have the same issue with my one months old  spark, Dronie  doesn't gain altitude , Helix just doing  half a circle and then keeps flying back in a straight line and the distance slider doesn't work at all, I sent my spark to DJI and they told me that it needs a new motherboard  at a cost of $370 or that I should use the refresh cover and pay them again.....
2017-8-8
Indi91
Flight distance : 103973 ft
Mine works nicely. I had it palm launched, then started dronie, it went back and elevated 8m (26ft) and 45m distance. Then it came back. So cool!
2017-8-8
