Crystal Sky not compatible with latest firmwares
1413 6 2017-7-3
fans2a1b5192
No software update available for the monitors?
Not compatible with Inspire 2. 100ft limit
2017-7-3
fanse9ca1f9e
Flight distance : 3031736 ft
I have the same issue, You can get it to work if you boot up on an iOS device, then disconnect iOS and plug in the CS.
2017-7-3
fans7c68f924
Flight distance : 58760 ft
With the latest version: V02.02.06.05 does not work well with the DJI GO and OSMO + application. Frozen image with a lot of noise.
Neither connects WIFI at 5.2G / 5.8G
How can I recover the previous Firware?
2017-7-4
fansd0df8aa0
Flight distance : 24928 ft
China
I hafe the same problem. Does anyone have a solution ?
2017-7-25
dronesinairs
fans7c68f924 Posted at 2017-7-4 23:04
You may be in the wrong thread. OP is having an issue with Inspire.
Your issue is with image and noise/DJI Go app and Osmo.
Firmware I am not sure but try either thread below.
Osmo+ Mavic DJI GO app video image transmission lag crystalsky FIX
http://forum.dji.com/forum.php?m ... mp;extra=#pid868905
DJI GO + DJI GO 4 = not working together on the same phone!!
http://forum.dji.com/thread-77838-1-1.html
2017-7-25
dronesinairs
fansd0df8aa0 Posted at 2017-7-25 22:21
See comment #5 above.
2017-7-25
Jense011
Thanks but !
I test it. first is not working !
Second works but not well ( frosen Pictures )
2017-7-26
