Compass error, Exit P-GPS Mode
18636 12 2017-7-4
a_savvin
Flight distance : 55840 ft
Hello,
I have not flied since November last year. On weekend I tried first time since.
I did software update and calibrated IMU, calibrated compass.
GPS P mode was green before I took off.
But after I took off I saw a red error "Compass error, Exit P-GPS Mode".
I did compass calibration and IMU again, but problem seems to me happens all the time after few sec after take off.
Thank you
2017-7-4
T-Rex
Flight distance : 966148 ft
Hi I ahi the same issue this Sunday. Luckily I managed to bring the drone back without any issue. I just chatted with Technical Support and I was told the error is caused by magnetic interference and I need to repeat compass calibration in an open area far form walls and metal objects. I will try next weekend.
2017-7-4
T-Rex
Hi I had the same issue this Sunday. Luckily I managed to bring the drone back without any issue. I just chatted with Technical Support and I was told the error is caused by magnetic interference and I need to repeat compass calibration in an open area far form walls and metal objects. I will try next weekend.
2017-7-4
a_savvin
I tried to compass calibration a few times and still no luck. I am in open are in the middle of soccer field. I can't recall last year I had same issue. Not sure if this is caused by firmware upgrade or so.
2017-7-4
JW5255
Flight distance : 5291158 ft
a_savvin Posted at 2017-7-4 11:55
When ever I have had to do compass calibration, I had to look process up again.  Never seem to do it right unless I review it first.
2017-7-4
a_savvin
Ordered new compass just in case.
Tried reset compass with little magnet.
2017-7-5
a_savvin
T-Rex Posted at 2017-7-4 11:34
Hello! How did go with your compass issue?
Thank you
2017-7-17
T-Rex
a_savvin Posted at 2017-7-17 06:05
Thank you
Hi! So far so good. I repeated compass calibration in an open area. Since then I flew twice and compass error didn't come out again. Probably it was a kind of interference in the location where the error came up.
Finger crossed !
2017-7-17
Callatis
Flight distance : 511112 ft
I had this once, after upgrading the P4, when flying over a house. The owner advised me there are a lot of interference in the area. I didn't see that again.
2017-7-17
a_savvin
Good for your. I guess I will replace compass myself and see
2017-7-17
a_savvin
Yeah I spend some time today and replaced compass. I dont see error any more. I did not go outside but what was fail before seems to me OK now.
I noticed some cracks in plastics when motors  assembled. Actually it was good experience since I found screws hard to un tide. I think thats why cracks on plastic.
2017-7-19
solentlife
Flight distance : 1087530 ft
Latvia
"I am in open are in the middle of soccer field. "
Many sports fields have a lot of pipework and gear under the surface to help maintain the 'grass' ....
It is not unusual for Compass Calibration to be made in a location. all appears OK, you take off and then within a few metres "Compass ERROR" ... why ?
Basically you calibrated in an area of interference. the calibration will only reject if the interference is significant. The calibration is within tolerance and confirms. But once the AC moves out of the interference - the compass is detected as having error.
Typical places NOT to do calibration :
Driveways up to houses
Roads
Car-parks with lots of street lights / utilities
Football / Sport fields
Concrete slabs / areas
Boat docks / Pontoons
Basically anywhere there is metal or piping / cabling ...
You are much better in completing calibration in an open clear farm field and then LEAVING it alone even if you fly at another location. Unless you move hundreds of miles - it will be perfectly safe.
Nigel
2017-7-19
djiuser_zzQLCqwMttVF
Bei mir ist es gerade auch so aber es ist jetzt das zweite Mal des kann man beheben indem man oben in der Mitte wo ready to fly steht driafdrüvken dan steht Kompass und dan auf  Kalibrieren und dann auf ok
2020-3-24
