Ex Machina
Flight distance : 1806362 ft
Mari Posted at 2017-7-6 12:21
Can you explain what to copy? And maybe how (new to iOS)...I'm also missing a few flightrecord on my iOS device.
You should think that if you sync both devices, all of the flight records should be on the server and later also on both devices?
Yeah, that would be nice if the cloud could sync all your devices bidirectionally.
You manage files in iOS via iTunes' File Sharing section. To sync flightRecords, you need to mix the contents of your two device's flightRecords folders together, and then copy back to the devices. On iOS, you'd drag the flightRecords folder to your computer, add the missing files, and then drag it back onto iTunes to update your iOS device. This is also how you'd copy your Downlink Videos off the device all at once, by copying the videoCache folder over to your desktop. Hope this helps.
