CrystalSky update glitch with inspire 2
1657 8 2017-7-7
fans2b2b9ba7
Flight distance : 15058491 ft
Fully updated CS 5.5 with a fully updated Inspire 2.  When starting everything up, the Go4 on the CS reports that the firmware is current.  A dialogue box pops up for a Data Update (Connect aircraft to update your data), followed by a two step instruction on how to connect with a USB cable. I set the switch on the I2 to the up position (mobile device), and connect the cable before hitting OK.  After that, nothing happens, and the system functions normally until the next time I start up everything.
Steps taken:
CrystalSky update (fully updated)
CrystalSky factory reset, then update check (still fully updated)
Checked firmware of I2 using Go4 on an iPad.  iPad confirms what thet CS reported. Firmware on I2 is up to date.
I'm baffled.
CS5.5 Inspire 2 update fail
2017-7-7
fans8a073583
Flight distance : 10566736 ft
Thanks for raising this question , I was just looking for the same subject
2017-7-7
Craignos
Flight distance : 5574954 ft
Ditto. And the instruction screen that follows this one doesn't make sense, or isn't clear as to what we are supposed to do (with the "attached" cable?)
2017-7-10
Dan M
Adding to the fun, the system now also tells me that there is a firmware mismatch. Since the CS and I2 system are both fully updated, I can't imagine how that is actually possible.
2017-7-11
eggbeater
Flight distance : 3502972 ft
Dan M Posted at 2017-7-11 10:39
welcome to beta testing.
2017-7-12
Craignos
This still appears on my CrystalSky device, DJI, any explanation yet?
2017-8-22
Uptowndisco
Flight distance : 7394987 ft
Same is happening on my P4P with built in screen , I was going to buy the Crystalsky for my Inspire 2 , but I am now having second thoughts
after reading the problem posts for Crystalsky and just stick with my  Ipad Air 2 .
2017-9-10
fans7785f203
Flight distance : 2106706 ft
Same issue on my new crystalsky with cendence. X7 works completely fine on ipad and regular controller.  Also cant focus the camera or change from photo to video on the cendence/cyrstalsky... whats with the I2 regular control options being even more basic than the cendence as well?? BS
2017-12-14
fans7785f203
My crystalsky is also stuck in M exposure mode, the AF/MF button is dimmed as if it is unavailable...
2017-12-14
