IMU Error. Calibrate IMU when P4 starts up
10187 31 2017-7-7
ibuyufo
Flight distance : 819098 ft
I was wondering if this message is normal when the P4 starts up?  I upgraded to the newest firmware yesterday and have done calibration via the DJI assistant 2 for the VSP.  I calibrarted the IMU, Gimbal, and Compass after the upgrade.  I don't remember if it used to say this but now whenever I start up the P4, it says IMU Error and to calibrate the IMU.  I've tried to do multiple IMU calibrations and it's always the same message.  Can anyone chime in and let me know if this is normal?  Thanks!
2017-7-7
Punchbuggy
Flight distance : 483166 ft
Did it go away? I noted that message on the main screen, but also that the sensor page reported 'IMU warming up...'. When it then displayed the IMUs as both good, the message had gone away on the main page as good to go. I think the error message is a bug.
2017-7-7
Suhail78
Flight distance : 539531 ft
i had this same issue after my first flight using the new firmware.  instead of displaying the normal "IMU Warming up" message, it gave me the "IMU Error: Calibrate IMU", and all 4 LEDs were solid red....  but also the sensor page showed "IMU Warming up..."   After  a few seconds i got the green "Good to Fly  (GPS)" message, and the flight went pretty smooth after that.....seems like a firmware bug...hope they fix this soon...
2017-7-8
Chief RM
Flight distance : 136204 ft
I had the same when I flew today. So tried to do the IMU calibration and the bar graph on IMU 1 went to about 95% and a green light came on. Then went to 2 and stayed there for at least a half hour. Never did calibrate and now I get the warning to calibrate the IMU. To hot to fly now so will try and fly in the morning and see what happens. May have to go to DJI Assistant 2 and revert back to previous firmware.
2017-7-8
Dnerve
Flight distance : 523799 ft
Punchbuggy Posted at 2017-7-7 22:35
Exact same behaviour, message clears up after IMU has finished its warm-up cycle.
I re-calibrated and same occurs, all readings are in the green when the IMU comes online.
I just guess the new firmware sends some signals the app hasn't been updated for the P4 in regards to the IMU warming-up sequence.
2017-7-8
ibuyufo
Thanks all.  I hope it's just a software bug and I also hope DJI addresses this in "future" update(s).
2017-7-8
fester
Flight distance : 77408 ft
ibuyufo Posted at 2017-7-8 15:58
Same here. I think its just a bug that flags a "recalibrate IMU" instead of "IMU warming up". The warning disappears shortly and gives a Ready To Fly, so probably just a bug.
2017-7-8
ibuyufo
I can't fly my p4 today and couldn't fly it yesterday as well because it's super windy here.
2017-7-8
Chief RM
Chief RM Posted at 2017-7-8 10:17
to calibrate the IMU with the new firmware pay attention to the positioning the P4 while doing the calibration. I didn't and didn't get a good calibration. After a tip on the P4 facebook page I followed the positioning during calibration and the P4 calibrated perfectly. Still get the calibrate the IMU prior to take off but the bird flies perfectly.
2017-7-9
Jgrimmy
Flight distance : 90653 ft
Glad to see I'm not the only one!
2017-7-14
P4 Roy
Flight distance : 5435299 ft
I get the message too since updating firmware, it went away once warmed up.
2017-7-14
Callatis
Flight distance : 511112 ft
I am getting the same IMU error every time I turn on the P4. Waiting to warm up the error goes away.
2017-7-14
Oz Phantom
Flight distance : 79462 ft
me too DJI P4 IMU warning everytime, unstable jerky  flight and the feed cuts out and gimbal shoots off to weird angles, all since update had none of these issues day prior to firmware update
2017-7-14
mrdarbab
Flight distance : 111086 ft
Oz Phantom Posted at 2017-7-14 20:16
That makes me feel better, I  thought I had a bad IMU. Do you get advanced flight modes in the sim, I don't after the update.
2017-7-15
fansa84fe8a4
Flight distance : 3 ft
New firmware had me do all six sides of the P4 (old one) now.  Before it just sat there on level ground.  Flies pretty well now and better than my recently updated I2 too which is sort of wonky (Hovers crooked, but gimbal is level.).
2017-7-15
djikev333d
Flight distance : 598130 ft
is everyone just flying with this error on startup? I have this same issue "ever since" the latest firmware update to v02.00.0106 mid july...from this I tried updating the firmware via a pc it must have messed up something, I got a "camera Sensor Error" black video output on ipad. anyway I had to send it to DJI and the gladly fixed that error, but sent it back with this same IMU error, they flight tested back in California too. I dont see how they could miss this error on startup other than not paying attention, because once the GPS picks up, the error goes away, but I have noticed that sometime I will see a message that the IMU redundant switch occured, and if I check sure enough the DJI Go app indicates it switched to IMU ACC #2.... Im waiting to hear back from DJI email support
2017-8-11
fansfb11ee43
Flight distance : 298875 ft
djikev333d Posted at 2017-8-11 15:46
It started happening to me to after the firmware update, most likely it happening to everyone, fortunately it goes away, unlike the map section in the app going suddenly blank and then having to reinstall the GO4 app to get it working again.
2017-8-11
FredAstra
Flight distance : 595577 ft
Suhail78 Posted at 2017-7-8 07:06
Ditto - Exactly the same with me
2017-8-12
FredAstra
I had this same problem.. which is because the NEW IMU calibration method which requires you to move the position of the phantom at each stage of the IMU calibration. check this
2017-8-12
djikev333d
I got a reply from DJI, its now a known issue, they have read this thread and are working on a fix in a firmware update, kinda ironic.
For now the recommend "warming up" longer,  read below.....from DJI
We are glad that the steps you have taken in calibrating the IMU has alleviated your concern for a bit. Our Team is working on the double in finding a fix for this particular concern that you are encountering with your drone.
For now, we would recommend you to warm up your aircraft first before using for  any intended purpose while we are seeking a fix of the issue.
Rest assured that we will notify you once we got an update for any firmware or hardware concerns that is a suitable fix for the issue.
2017-8-17
ninjapimp
Flight distance : 198222 ft
same exact issue. i've not found a fix yet for this.
2017-8-17
rudyasho
Flight distance : 547320 ft
Indonesia
saya juga mengalami ini pada android   seri menengah dan terakhir selalu saya paksakan sehingga kini  tidak bisa digunakan
2017-8-17
djikev333d
ninjapimp Posted at 2017-8-17 06:07
read the response from DJI right above your post, there is no fix for this. Period.
2017-8-17
ibuyufo
djikev333d Posted at 2017-8-17 09:54
Anything can be fixed if they put some damn time into it.
2017-8-17
rudyasho
Indonesia
This is not normal. I experienced this kind of incident on android with a small RAM of only 2 gb, when I changed devices then this did not happen again
2017-8-18
Caron
Flight distance : 77589 ft
I have the same problem with the calibrate IMU message when i start phantom4, I'm still waiting for a solution because after warming up the error disappear and the PH4 flies without any problems.
2017-10-31
DJI Elektra
Did the message go away after a few minutes? If not, please inform us. Please note that if the message go away when your drone start up, it will not affect the flight performance. This problem will be fixed in the next version.
2017-10-31
Satstream
Flight distance : 392024 ft
If you look at the page "Sensors" you can see that the sensors are switching to green, so you can start calmly.
2017-10-31
Tomas Kozacek
Flight distance : 1520220 ft
Czechia
I have the same message when my drone boot up, but as soon as warm up the message is gone and I never have any problem with the IMU.
2017-10-31
fansa84fe8a4
Same "IMU Calibration Needed" warning on starting up here as well yesterday even though I did it last week with a new iPad and GO 4.  It did go away after warming up, but then the gimbal went limp in flight.  One issue self-corrects, and another one breaks.
For a while I was thinking I might need to bring my leveling platform and carpenter's level for fixing this in the field if it didn't clear the warning, or cancel the flight and haul it all home 20 miles away to re-calibrate.
Wish DJI would fix their stuff.  This lousy firmware matter has been going on since July and it's getting pretty old.
2017-10-31
fans91026583
Depuis la dernière mis à jour, je ne peux faire voler mon drone p4 je peux pas calibrer lui affichage error -13 , quelqu'un a t il la solution je désespère je suis en Guyane !!
2017-12-3
Regis*Brazil
Brazil
Hello my friends, I have the same problem, but when I call the drone this message in yellow "IMU ERROR" after a few minutes the message turns green and the drone is ready for flight, here in Brazil the ambient climatic temperature changes frequently, , when the weather warms here I have the message "ESC ERROR LANDING" in flight,
please help me with this question
2018-1-22
