Illegal to "catch" a drone?
1533 12 2017-7-7
fansdbce68d7
Flight distance : 349793 ft
According to:
http://dronelawjournal.com/model-aircraft-operations/
You must operate under AMA guideline to fly a drone recreationally in the USA. Does this mean DJI is condoning breaking the law in the USA with the "hand launch/catch" features?
Per the AMA rules:
“Hand-catch” landings are prohibited. Rather than landing them upon the ground, some operators prefer to hand catch their multi-rotors, either all of the time or under certain conditions. This is strictly forbidden under the AMA Safety Code.
See AMA Safety Code paragraph B(7)) — “Under no circumstances may a pilot or other person touch an outdoor model aircraft in flight while it is still under power, except to divert it from striking an individual.”
2017-7-7
LeChuck71
Flight distance : 68786 ft
Well different countries different regulations
2017-7-7
LeChuck71
Don't "catch" it if you are in the US ;)
2017-7-7
Tviscomi
Flight distance : 106886 ft
The AMA is NOT a governing body, thus these are just safety guidelines..  I fly my drones and fixed wings at an AMA field, thus I am suppose to adhere to these guidelines.
2017-7-8
fansdbce68d7
Tviscomi Posted at 2017-7-8 01:48
According to dronelawjournal, you MUST fly in accordance with the AMA rules at all times, whether you are a member or not.
2017-7-8
Tviscomi
fansdbce68d7 Posted at 2017-7-8 09:53
Once again...the AMA , which I am a member of, is NOT a governing body.  They are the equivalent to the NRA.  There's not a snowballs chance in hell that DJI, who also lobbies for less stringent rules would market the Spark for "Palm landing" if there was a FAA rule against it.
2017-7-8
Tviscomi
“…model aircraft may be flow consistently with Section 336 and agency guidelines at altitudes above 400 feet when following a community-based organization’s safety guidelines.”  As per the FAA
2017-7-8
SMacDrone
Flight distance : 1700981 ft
I hand catch all the time.  There is NO rule against it and if you know what you are doing it is safer for you and your drone.
2017-7-8
FatherXmas
Flight distance : 4058619 ft
Either dronelawjournal is totally wrong or you have misinterpreted it. AMA has zero legal authority over drones, they just publish guidelines which don't have to be followed. The FAA rules are the only thing we have to pay any attention to here in the U.S.
2017-7-8
FatherXmas
FatherXmas Posted at 2017-7-8 12:05
Well, I did further research because I was curious,  dronelawjournal refers to Part 101. I found a legal brief summarizing Part 101- balloons, kites, para sails, no drones mentioned, so they are totally incorrect.
The FAA's website says that recreational drones fall under Public Law 112-95 Section 336. They do say 'Follow a community-based set of safety guidelines'  - pretty vague, my interpretation would be community based means local laws. They also say for more info, refer to the Fly for Fun page. There you'll find the usual stuff - under 400 feet, VLOS, not over people, etc. No where does it say you cannot hand catch.
2017-7-8
Tviscomi
FatherXmas Posted at 2017-7-8 13:23
The whole thing kinda jumps back & forth.  The FAA cite nationally recognized community based organizations, which there is only one in existence (AMA).  Then I stumbled across this:
http://amablog.modelaircraft.org ... /07/FAA-400feet.pdf
2017-7-8
Tviscomi
See below for some other contradictions between the FAA rules/guide lines and and the AMA safety rules.
Night flights are permitted. As long as the model aircraft is equipped with appropriate lighting to provide the pilot with a clear view of the model’s attitude and orientation at all times, you may fly in darkness. AMA
Flight altitudes are unrestricted, unless you are within three miles of an airport AMA
First person view (“FPV”) operation is permitted.AMA
2017-7-8
Mark Weiss
I saw this in a Youtube video. Item #7 in particular caught my attention.
2018-6-16
