avata7
South Africa
fansff9ccebf Posted at 2018-12-7 21:20
I've had the same problem with the unresponsive touchpad three times.. Two times before updating and one time after.. Plus, I just turned them on and the opening screen had green lines through it and froze, then restarted.. Also, I wear glasses because I can't see distance, so I didn't think the goggles would be a problem, but they always seem out of focus.. Only had them 24 hours and have had four problems with.. Seriously not happy..
hi there,,,
i have had the same ISSUE,,, here is what you need to do, at the language stage, the pointer showing on your smart phone how to swipe on touch pad ,,, YOU NEED TO PUT THE GOGGLES ON TO YOUR FACE whereby the goggle will switch on AND THEN THE TOUCH PAD WILL WORK ,,, each time you remove the goggle the screen is in sleep mode, so GOGGLE ON YOUR FACE, proceed with the different steps / menu functions and THEREAFTER, the blue GO FLY will appear on your smart phone |
