christing
Japan
You can try the best DJI video converter.
> This 4K h.265/h.264 converter enable you to transcode video of DJI OSMO, Insprire 2, Phantom 4, Phantom 4 Pro in H264 or h.265 to a format more suited to editing videos even on lower spec PCs and keep original 4K resolution. It needs a lot more space for transcoding.
> This software supports resizing video of Phantom 4 Pro in H265 from 4K to 1080p (full HD) and simultaneously save it with editable format like ProRes. In This will speed up a lot of processing the video in the editing software and also lesser PC powerful can work good.
> Join multiple DJI video clips into one. If you format the SD card in fat 32 the video recording limit in size stops at 4GB or so, then because of the file system tree instead of a single video you will find more multiple videos each of 4GB, to merge 2 or more DJI video files in one final video, you can also apply Brorsoft Video Converter with its "Merge into one file" function.
> Convert DJI H.264 or H.265 footage to Windows Media Player, YouTube, etc friendly format for easier playback and sharing. Not all media players yet support fully the H.265. YouTube and Windows Media Player do not support h.265. It is useless to play or send a video of Phantom 4 Pro in H265 on Windows Media Player, Youtube because it is not recognized. This powerful DJI transcoding tool brings you a smooth H.265 conversion process. |
