Asainz320
Flight distance : 1061594 ft
Sure!
For this one I used the Portrait Mode and shot around 45 pics. There are apps that will do this automatically for you. Litchi is one of them. I personally dont like doing it automatically because it takes longer than just doing it manually. I did the color correction and editing on Lightroom for all the shots. Make sure you set the AWB to manual, I forgot on this project and it was a mission to match white balance on all the shots! Also make sure to not add or make sure to remove any vignetting so when you stitch all the photos together they blend in nicely. After exporting the photos, I used Huggin on my Mac to stitch the whole pano together. There are other options for Windows. To share the 360 I used Kuula. You can upload pretty big panos there. This one I shared with you guys is not even the full resolution. It is the file I created to share on Facebook which only allows 6000x3000. The original pano I created was something like 13000x5000 or something like that. Good luck! |
