My Mavic mount for 5.5" CS
4255 25 2017-7-13
StianGel
Flight distance : 686654 ft
Norway
Did some machining today, and completed my CrystalSky 5.5" mount for the Mavic controller.
The baseplate is was machined out of a solid block of aluminium. Same for the bracket on the bracket for the CS.
The arm and the part that screws onto the CS is made of 2mm carbonfibre. Just because i had some lying around.
Does anyone know of a place to get a USB-C cable that has a 90 degree bend the other way?
Would love to get the cable secured to the arm.
The machined parts.
The machined parts.
Parts and hardware
Parts and hardware
Bracket, arm and holder.
All assembled.
All assembled.
Side view
Side view
Slant view.
Slant view.
CS mounted
CS mounted
Bottom view
Bottom view
Ready to fly
Ready to fly
Added some slots to lighten it, and possibly securing the cable
Underneath
Underneath
Hinges have lock nuts, so they stay where i put them
Raised up. Fits great in my hands
Different view
Different view
Side view assembled
Side view assembled
Bottom assembled
Bottom assembled
Yet another bottom picture
2017-7-13
Visualkaos
Flight distance : 755988 ft
Looks great!  Nice Job.
2017-7-13
fans88bebfcd
Flight distance : 6762 ft
Poland
It takes some searching but Amazon has both left and right  C to micro USB.
2017-7-14
StianGel
Norway
Amazon and shipping to Norway does not go well.
I found some myself, but they where either to long, or had the wrong connector in the other end.
Will look into modifying one myself.
2017-7-14
kg11
Flight distance : 25466 ft
New Zealand
StianGel Posted at 2017-7-14 01:35
Man that is beautiful work
Did you make this bracket specifically for the Mavic.
As I have the mavic and the inspire 2 and want the 5.5 inch crystal sky on both devices  but I was going to use the mounting bracket that came for the inspire 2 remote somehow with a plate for the mavic
Im on it
2017-7-15
StianGel
Norway
kg11 Posted at 2017-7-15 00:44
Thanks.
Yes, i made this specifically for my Mavic.
Thinking about replacing the screws that secure the CS with thumbscrews. That way i can easily remove it for whatever reason.
2017-7-15
kenavata
Flight distance : 742126 ft
Very impressive!
What are your initial thoughts on the Crystalsky, is it stable, noticeably brighter etc?
I'm always a little reticent of jumping into version 1.0 of a product.
Thx Ken
2017-7-15
StianGel
Norway
kenavata Posted at 2017-7-15 10:21
Very impressive!
I have had some issues when i first power up the Mavic, controller and CS.
Last time i was out, i had to do a reboot twice before the image was good. Had severe lag before the reboots.
Once i have it running smoothly, there are no app crashes. I did notice last time some minor stutters in the image transmission, but that could have been due to flying near power lines.
I still have not got to test it in direct sunlight, but it is way brighter then my phone. On the phone i had to manually select max brightness to get a decent view, the CS manages just fine in similar lighting conditions.
The holder allows me to get the screen higher above the controller leading to more relaxed operation.
I hope they will release a new firmware soon, as i see many people have issues with stuttering.
2017-7-15
Lucas775
Flight distance : 50642090 ft
Very well put together, good job!
2017-7-15
Woodwanger
Great job....I am still waiting for DJI to release the bracket I do not know why it is taking so long? The Mavic 2 with a built in Crystalsky will probably be out soon!!!!
2017-7-15
Nikon 1
StianGel - That is some beautiful machining!  Thank you for sharing your craftsmanship.  I have the 7.85 UltraBright on pre-order and was figuring on using a MavMount to my Mavic Controller - but IF someone comes out with a mount made with your craftsmanship, I may rethink that one.
Thank You
2017-7-16
mollyg
Flight distance : 194721 ft
You did a excellent job building the mount.
2017-7-21
Alexei Merinov
Flight distance : 4796509 ft
Vietnam
Beautifully it turned out! Functional and beautiful!
2017-7-22
StianGel
Norway
Since i could not find the perfect cable anywhere, i decided to try making my own.
Bought some USB-C and USB-A plugs online.
Sacrified a USB extension cable for the cable. Had a 4 lead witch was fairly thin.
Then i realized that my soldering skills was not up to the task. Stripped the wires and did the best i could with the soldering iron i have. (Should have gotten a thinner one.)
Did also run out of thin heatshrink tubing, so i placed the wires inside the arm and coverd it with heatshrink tubing.
Then i made sure that i did not have any short's before testing with my phone and PC first.
Will make a small shroud over the plugs when i get the chance.
Custome cable.
Custome cable.
2017-8-4
mavicspark
StianGel Posted at 2017-7-15 03:38
Thanks.
Very good idea!
Great work!
2017-8-14
StianGel
Norway
Got myself a new bag for the Mavic and remote-CS combo. A Manfrotto SB-A6.
So i modeled a protective cover and had a friend 3D print it as "my" mill was occupied.
Now it slides in and out of my bag without snagging on the USB plug.
Protective cover
Protective cover
2017-9-8
Mountaindrone
Flight distance : 26618251 ft
new official mount : http://store.dji.com/fr/product/ ... rc-mounting-bracket
2017-9-13
StianGel
Norway
Mountaindrone Posted at 2017-9-13 00:18
new official mount : http://store.dji.com/fr/product/crystalsky-mavic-spark-rc-mounting-bracket
I like the idea, but it looks like the cable sticking out could be damaged easily when placing the controller on the ground.
2017-9-13
DJI-Mark
Great job on the bracket. Here is a link that offers Mavic type cables through the online store: http://store.dji.com/product/mavic-rc-cable
2017-9-13
StianGel
Norway
DJI-Mark Posted at 2017-9-13 07:38
Thanks.
For the cable i was thinking of the one mounted on the DJI Mavic CrystalSky holder.
2017-9-13
DJI-Mark
StianGel Posted at 2017-9-13 08:20
Thanks.
It may be a bit smaller from what you are trying to accomplish. On the other hand, it is not always so obvious what is going on in the accessories department. Thank you for your posting as well. Some great information there.
2017-9-13
Mautrix Sharky
Amazing...did u sell it?
Take all' of my money
2017-10-13
StianGel
Norway
Mautrix Sharky Posted at 2017-10-13 05:19
I am using it myself.
I like having the screen above the controller, but still beeing able to see the screen onm the controller.
2017-10-13
fanse15a7184
Flight distance : 6900 ft
your mount design is soo nice. will.u sell it? i am looking for one fit for my CS 7.85..let me know. tthx
2017-12-13
fanse15a7184
fanse15a7184 Posted at 2017-12-13 18:31
my email is davidko@webgomedia.com contact me if you able to sell me one
2017-12-13
Chubpone
Is it possible to make one for me I’ll purchase it right away email is chubpone@chubpone.com
2018-3-21
