What editing software do you use?
3276 21 2017-7-13
SRPitera
Flight distance : 40889 ft
I use CyberLink, Power Director 13 to edit videos.  Its ok, but lags a ton when editing 4K.   Is there a better software at a reasonable price?   What do you use for your 4k editing?
Thanks guys
2017-7-13
Greg M.
Flight distance : 69442 ft
Magix VPX for years.
2017-7-13
hallmark007
Flight distance : 9827923 ft
FCP, it's pretty simple to use price $299 but worth it..
2017-7-13
Cetacean
Flight distance : 2528264 ft
Aloha SR,
     Sounds more like you have need for computer improvements.  4K is extremely demanding.  You should be using a computer with gaming or video editing specs.  If you think your computer is up to the 4K task you could try DaVinci Resolve 12.5.  It is free.  It also has the best color correction available.
Aloha and Drone On!
2017-7-14
Capo
Flight distance : 178196 ft
Agree with Davinci Resolve. Full featured and free for single user use. One thing it does is allow you to optimize files for editing at a lower resolution and then render full resolution when complete. Some other professional packages also do this. This allows you to edit video with little lag, and finish rendering when you are away from the computer. As others have said, 4K video is extremely demanding. Best to use a software that can use the GPU and have a computer that has a powerful GPU as CPU's are not very efficient for rendering.
2017-7-14
FuZZyPiLOT
Flight distance : 1353215 ft
Wondershare Filmora for Windows
2017-7-14
Rob W
Flight distance : 94390 ft
Sweden
I use DaVinci Resolve Studio, Final Cut Pro X, Motion, After Effects, Film Convert, Blender.
2017-7-14
JoiCam
Flight distance : 771434 ft
Iceland
Grassvalley Edius WG and Davinci Resolve Studio
2017-7-15
Flying Wolf_NOL
Flight distance : 345827 ft
Don't laugh... I just use iMovie     <.<    ..... BUT about to upgrade to FCP  (soon I hope).
2017-7-15
Aardvark
Flight distance : 384432 ft
Movie Studio Platinum 13, bought end of last year ( now at 14 I believe ) works well for me on quite a beefy desktop and has full 4k support.
Working with 4k video usually requires quite a bit of processing power, Movie Studio (and perhaps most editors, I don't know) can create 'proxy' files to work with in editor (1080P versions). When editing is completed it can apply all these changes to a 4k rendered version (or whatever resolution you chose). It is of course 'non destructive editing' leaving the original files undisturbed.
2017-7-15
dcap
i use vegas pro 14, resolve, and after effects
2017-7-15
theGrindLab.com
Flight distance : 1375846 ft
dcap Posted at 2017-7-15 09:13
Vegas Pro 14 here too.
2017-7-15
Rodger8
Flight distance : 20145135 ft
Final Cut Pro is great if you have an IOS device.
2017-7-16
SRPitera
I am using a Lenovo Y70.   I think its a pretty powerful PC:
Spec list
•CPU: 2.5GHz Intel Core i7-4710HQ (quad-core, 6MB cache)
•Graphics: Nvidia GeForce GTX 860M (4GB GDDR5 RAM)
•RAM: 16GB DDR3L.
•Screen: 17.3-inch, 1,920 x 1,080 FHD multi-touch screen.
•Storage: Hybrid 1TB (5400 RPM) plus 8GB SSD.
Your thoughts?
2017-7-16
Shaker
I'm using PD15.
I'm no expert but i'd say
Your specs sound good for RAW processing.  And for light to medium VIDEO processing ... maybe.
16 RAM is, I feel, a minimum.
Your Sata drive is a weak point, An 8GB ssd card is nearly useless except for one project at a time efforts.
Remember, as any drive gets full of data, the processing capacity diminishes.
I have 32 RAM Nividia 970 and 2 500G ssd drives
even not when processing 4k VIDS I often need to export each single step of a small project.
EI:  stabilize clips ... process (produce)
       color corrections and a few effects on the processed clips ... process again
Your computer will do the job ... with patience ...
doubling memory, and a faster drive (a 7200 or a ssd/ and a 256G ssd instead of the 8G (about $150) would help a lot
2017-7-16
Punchbuggy
Flight distance : 483166 ft
FuZZyPiLOT Posted at 2017-7-14 06:50
+1 for Filmora. I looked into a number before settling on Filmora. At one extreme DaVincu Resolve offers amazing capability but not as easy to pick up and use as others, and required a powerful CPU and GPU to operate well. I grew frustrated with it fast. Filmora, on the other hand, purrs along quite happily on a lesser processor and I was able to start building videos within a couple of plays. I've only recently discovered how to use some of the transition and frame effects to good use, as well as some of the other 'add ons' such as the video cutter.
2017-7-16
dancopter
Flight distance : 17901030 ft
United Arab Emirates
+1 for Davinci resolve. Has all I need for a hobbyist like me.
2017-7-16
Jane Smith
I use TunesKit AceMovi to edit videos. It's similar to Filmora but much cheaper. More importantly, you can now get it for free. You can use it to create and edit your video with basic and advanced editing tools like cropping, cutting, splitting, add text & music, apply filters, transitions, animations, split-screen, and many other cool effects.
2021-1-4
Chris Lampard
Russia
The cheaper and easier to use (and obviously not as fancy or as many functions) is Movavi Video Editor. Good for editing, adding sounds, adding callouts and etc. Pretty much intuitive to learn.
2021-7-3
djiuser_kkwn8rIwX3KI
India
I am using Davinci Resolve
2021-11-23
MassDrone
Flight distance : 894642 ft
I use Premiere CC on a Mac laptop with an external Vega-64 GPU.  The system edits and compiles 4K video just fine.
2021-11-29
Mark Weiss
Using Premiere Pro on a dual Xeon E5-2667 workstation.
2021-12-3
