Mabou2
Flight distance : 811257 ft
Hi Jamie,
I'm going to ask the obvious questions... kind of akin to "is the TV plugged into the wall"?
1) Did you connect to DJI (via the internet) after the update? If not, your speeds and distance are greatly reduced.
2) Did you have the volume up on your mobile device? If so, did you hear the beeps telling you that obstacle avoidance in kicking in? I have been confused many times lately about my P4P suddenly flying very sluggishly, only to realize that Obstacle avoidance was actually doing its job.
3) Did you turn off beginner mode?
4) Do you have a gimbal guard installed?
5) Did you notice what the elevation was in DJIGO4? (Maybe check your flight records)... could be that your drone thought it was only a few feet off the ground the entire time, so it slowed down.
I realize that much of this wouldn't amount to a drone acting the way you described, but these comments would be good to review (and eliminate) because DJI might ask the same.
