Punchbuggy
Flight distance : 483166 ft
Aardvark Posted at 2017-7-16 14:41
I thought the same initially, then not, but then back again :-)
At some point during calibration it needs to know what 'level' is, otherwise how can it judge when it's not level (I know). So lets supposing you've had a bad night and you think that the desk is level, it is in fact a 10 degree slope. At two points during the calibration it would expect to be level, one when on its feet (taking a reading at +10 degrees), and two when sitting on the motors(taking a reading at -10 degrees). So to compensate for any error between the two readings it would 'split the difference' and end up with a dead level setting ? And the four side calibrations give it an indication of how far it can tilt in each direction.
Just my $0.02 - I have to agree that the surface still needs to be level. It's logical that it relies on that to be able to assume a zero baseline to set any required IMU off-sets (as determined from the angles). Again, using logic, the 'dance' may simply be a way for the dual sensors to self-check the settings from multiple angles - which is what you just said Aardvark.
But did I use 'logical' twice then? (hehe) |
