Auto Calibration Doesn't work and Gimbal wobbles
2790 9 2017-7-18
Dzeisen
Singapore
After upgrading to the latest firmware just today, the auto calibration failed with the device facing downwards and the app showing the message to reboot the device. In addition, during the auto calibration, the gimbal wobbles ever so slightly during the entire process.
After the calibration has completed (albeit it failed), the gimbal continues to wobble. Even when I shut off the gimbal and powered on again, the gimbal always attempts to stabilize even without the phone in it. Before the firmware upgrade, powering on the gimbal without a phone will do nothing to the gimbal.
Has anyone encountered such issues? How can I resolve this?
2017-7-18
Dzeisen
Singapore
I also noticed that the Gimbal heats up really quickly and makes a rather loud hissing noise even when there is no device in it.
2017-7-18
We are sorry for the experience with our product. Please compare all the gimbal motors, only one heats up quickly or all heat up? Is there any obvious difference?
Besides, is the gimbal balanced before powering on?
2017-7-18
Dzeisen
Singapore
DJI Mindy Posted at 2017-7-18 02:54
The motor behind as well as the side is equally as hot. I have not encountered this prior to the firmware upgrade.
The gimbal is basically useless now that it can no longer auto calibrate properly.
2017-7-18
Dzeisen
Singapore
The gimbal was properly balanced prior to the firmware upgrade and I always recalibrate osmo mobile after a firmware upgrade.
Now whenever the gimbal is powered on even without a device, it always attempts to balance before it falls down.
2017-7-18
Dzeisen Posted at 2017-7-18 03:20
Please try to download DJI Assistant 2 to your computer and then connect Osmo Mobile to your computer. Log in DJI account, you will see the status of Osmo Mobile, please check if the firmware updated successfully.
Here is the link to download DJI Assistant 2: http://www.dji.com/osmo-mobile/info#downloads
2017-7-19
待疯狂的渣渣
Flight distance : 61214 ft
Dzeisen,  re-upgrading again?
2017-7-19
Dzeisen
Singapore
DJI Mindy Posted at 2017-7-19 01:50
I have done that. There is only one firmware and I have confirmed that the upgrade was successful. Is there anyway to downgrade the firmware?
2017-7-19
Dzeisen Posted at 2017-7-19 07:18
I'm sorry that the firmware cannot be downgraded, please contact support to send it in for evaluation and repair, we apologize for the trouble caused.
2017-7-20
Indian
Norway
Me too have the same problem with auto calibration after the update which was done with the assistant. It ends with the phone facing downwards and told to reboot. The gimbal does not get hot.
2018-7-8
