sounds like you have it turned off in the DJI GO4 app settings. I know the settings are top right of the screen...im sure someone else can give you the exact location of this setting
Just to verify, had you removed the protection film on the vision system and the 3D sensor system? If it is a new drone and has not removed, please try to remove.
Same problem here. Yes protective film is off. Using IOS and the cable, flying 2.4G. It a software bug.
Also the signal indicator is not showing anyting on 2.4G and using the cable. It's also a bug. My friends have the same issue.
Using Android and wireless between RC at phone, and the indicators is OK.
Hoping and waiting for a new bug free firmware update.
jangermann Posted at 2017-7-21 00:33
Hi, I don't know if you can call it a bug or not because dji never advise to use OTG cable.
On the contrary, seems like OTG give more reliable connection.
Are you using the prop guards? I discovered recently that each guard belongs to a specific arm, not just black or white dot. If installed incorrectly, the prop guard will be detected by the CA system, and make it useless to fly, always alerting you.
Hi
I also have a question with Obstacle detection. I am using an iPhone to fly spark, if I TURN OFF the obstacle detection, do anyone knows if it will increase my top speed?
sparktacus Posted at 2017-7-22 02:22
Hi
Yes, it should increase your speed from 6mph to around 12mph if you disable obstacle detection.
