Black spot on photo/movie
1262 9 2017-7-21
Tedeus
Poland
Hi guys,
Black spot appears on my photos and movies (left top of the screen). I tried to clean camera, but it doesnt work. Any Idea?
2017-7-21
MARSAN
Flight distance : 966978 ft
Belgium
If that spot is always in the same place, then it's probably dirt on the image sensor.
2017-7-21
Tedeus
Poland
How to clean it? Do You have any video?
2017-7-21
Ex Machina
Flight distance : 1806362 ft
Tedeus Posted at 2017-7-21 04:43
Sadly it's not repairable by the end user, you'll need to send it back. ;(
2017-7-21
MARSAN
Belgium
You'd have to take the camera apart to get to the image sensor.
Very tricky job, since the camera is very tiny and you could break even more.
Better have DJI do it for you.
2017-7-21
Asainz320
Flight distance : 1061594 ft
I would try flicking the camera to see if the particle wants to come loose from the sensor.
2017-7-21
Asainz320
Or maybe put your phone to vibrate and touch the camera with it while vibrating. Hopefully the vibration will remove the particle. The thing is that you would still have that dirt inside the camera so it could appear again at any moment.
2017-7-21
DJI Diana
Flight distance : 2408 ft
I would recommend you send it in for service, have you contacted the Support to start a case? If not , please contact them here:  http://www.dji.com/support
2017-7-21
MARSAN
Belgium
Asainz320 Posted at 2017-7-21 09:41
Your method may work, if the user is very lucky.
On my Nikon D300s there is a built-in option to make the image sensor vibrate, but from personal experience I know that this doesn't clean the sensor.
Our air is saturated with all sorts of obnoxious particles, like pollen, yeast, dust and other yecchy stuff that can really stick like glue to an image sensor.
2017-7-22
Asainz320
I believe the vibrations on the sensor of the DSLRs is ultrasonic. In my personal experience I have seen it work. I'm always extremely picky when it comes to changing the lens on my DSLR. I always make the change very quickly and try to minimize as much as possible the time the lens port is wide open. Still, I have gotten specks on my sensor. In the 3-4 years that I've had this camera I haven't manually clean the sensor once. I always use the sensor cleaning option on the camera and it has worked flawlessly. Im sure there will be a time that the particle will be so stuck that the sensor wont be able to shake it off, but until now it has worked as described
2017-7-24
