help with jumpy lines in video
754 5 2017-7-21
WICKET
Flight distance : 121 ft
https://www.youtube.com/watch?v=8J2HWSi2lZI
I'm getting funny looking video every now and then and csant figureout what the deal is?  The lines show up about 25-28sec in this.  Ive searched the forums but had no luck finding the same thing with the search feature.
2017-7-21
WICKET
Sorry just realized the video was set to private.
2017-7-21
Ex Machina
Flight distance : 1806362 ft
That happens when the gimbal becomes overextended and can no longer dampen movement, typically happens with wind gusts or sudden navigational changes, especially in Sports Mode.
2017-7-21
DJI Diana
Flight distance : 2408 ft
Post 3# is correct , you can try to calibrate the gimbal, it may be helpful.
2017-7-21
jpap
Flight distance : 1780679 ft
Hungary
You may also try to fly smoothly. Don't do abrupt moves with your sticks. Even slowing down sometimes needs to be smooth, it takes some practice.
Winds , as others said, will amplify this phenomenon. Try gimbal and IMU calibrations, and if the problem persists, meaning it's happening quite often,  (especially when no wind) you may need to contact DJI.
2017-7-21
WICKET
Thanks guys I'm guessing it was the wind.  I did get a warning one or two times
2017-7-22
