70+ Days and counting
1276 8 2017-7-22
NE.UK
Flight distance : 25371 ft
Status on my manufaturing fault repair...
What does this status mean?
2017-7-22
NE.UK
Text says
Some required information is missing, we will contact as soon as possible
2017-7-22
hallmark007
Flight distance : 9827923 ft
NE.UK Posted at 2017-7-22 16:12
Text says
Your not great at giving information yourself....
2017-7-22
Would you please provide me the case number so that I can check more information? Thanks.
2017-7-22
NE.UK
DJI Mindy Posted at 2017-7-22 18:15
As requested:
CAS-755613-M3Q1G2
Thank you
2017-7-22
NE.UK Posted at 2017-7-22 20:00
As requested:
CAS-755613-M3Q1G2
Thanks, the drone is conducting data analysis, we need more information. Could you please export flight records to us at your most convenience?
If you used Android mobile device during flight, please connect your phone to computer, find the DJI Go 4, send the whole folder records file to us.
If you used iPhone, install iTunes firstly in your computer, run it and find DJI Go 4 program, export the whole flight records folder.
You can upload the folder to Dropbox and post the link to us, we will make analysis as soon as possible. Thanks in advance.
2017-7-22
NE.UK
DJI Mindy Posted at 2017-7-22 20:33
Please find the logs linked below
link 1 - drone disconnects and nearly drifts into my car, i had to grab it in flight and pull out the battery. (click notification tab)
http://app.airdata.com/main?share=rLMCDi
link 2 - random disconnect for 30 seconds
http://app.airdata.com/main?share=pOTqqA
I don't have many logs on my phone as part of the troubleshooting process it was suggested that I should completely uninstall DJI Go and re-install. I don't see why DJI can't get the logs off the drone though.
The logs clearly show the drone completely disconnecting from the drone... Downlink data connection lost for 29.7 seconds
My phone is syncing with Airdata automatically these are the only logs I have.
The logs can also be found here: https://drive.google.com/drive/f ... UmxaNTg?usp=sharing
@DJI_Mindy it will be great if you update "CAS-755613-M3Q1G2" and achknowledge receipt.
2017-7-23
NE.UK
I have had a quick look on the mavicpilots forum and seems there are dozens of cases between all the forums,  The logs also look the same as the issue I had, I don't understand why it is taking so long for DJI to investigate this....
Here are some
** https://mavicpilots.com/threads/disconnect.17721/
** https://mavicpilots.com/threads/rc-disconnect.18626/
** https://mavicpilots.com/threads/700-disconnect.16246/
** https://mavicpilots.com/threads/aircraft-disconnected.14000/
** https://mavicpilots.com/threads/ ... 16246/#post-186287/
2017-7-23
Thanks for your update. I'm sorry that we must analyze your own flight records rather than other's similar records.
Really sorry to have kept you waiting for a long time, but we still need some more time to figure out the crash reason, your understanding and patience will be much appreciated.
2017-7-23
