DJI Assistant 2
7159 10 2017-7-24
FlyingDave
I have tried to download DJI Assistant 2 to my Mac several times. After downloading, it asks me to install something called HoRNDIS driver. I did this and then nothing. I cannot find DJI Assistant 2 or HoRNDIS anywhere on my Mac. Does anyone know what is going on here?
2017-7-24
Nelsonlee
Flight distance : 2779203 ft
Malaysia
Maybe you can try look on here: http://joshuawise.com/horndis
2017-7-24
ali86
Flight distance : 49078 ft
Malaysia
Mine's ok bro....try to look under application...the app in named as "Assistant" with the blue logo
2017-7-24
DJI Susan
Here is a tutorial video of installing DJI Assistant 2 in Mac OS for Phantom 4. The installing method is similar with Spark, just for reference.
2017-7-25
FlyingDave
ali86 Posted at 2017-7-24 19:21
Yes, it is there. Just called plain Assistant. I will see if it works.
2017-7-25
FlyingDave
FlyingDave Posted at 2017-7-25 11:50
It does work. I was able to refresh the firmware and download the black box. I guess you can't use this app to upgrade the remote controller's firmware?
2017-7-25
ali86
Malaysia
FlyingDave Posted at 2017-7-25 12:13
That's correct...I read somewhere in this forum before that you can't connect the RC to Assistant...As for now, it only for with the Spark...
2017-7-25
lafoto
Flight distance : 1402680 ft
Portugal
DJI Susan Posted at 2017-7-25 03:19
https://youtu.be/Gnyqjkmgn6I
Just installed...
Everything ok...
2017-7-30
Lucas775
Flight distance : 50642090 ft
Same here, downloaded with no problem.
2017-7-30
djiuser_7b22NlZf4WC2
Japan
O air unit não conecta com o goggle e o controle ao mesmo tempo antes de fazer a conexão com a assistant ele se conectava?
2020-11-10
Japan
2020-11-10
