[Resolved] (dji mavic) drone vibrates massively in air
707 7 2017-7-25
fans2a31cac7
Flight distance : 141253 ft
when i set the drone up off the air at about 2 meters up it vibrates and doesn't stop. does anybody know how to stop this. please help as i am in scotland hopeing to fix it can get some good photos and video, dji assistent 2 also doesn't reconise the drone or the drone controller.
2017-7-25
hallmark007
Flight distance : 9827923 ft
It sounds like problem with prop or motor , does it happen on the ground?
2017-7-25
fans2a31cac7
no, i fully extened the props because they are a bit stiff
2017-7-25
DroneFlying
Flight distance : 10774613 ft
fans2a31cac7 Posted at 2017-7-25 15:02
Was it flying without any problems before? Make sure you have the propeller cage option turned off and if it was already off then try an IMU calibration.
As far as your problems with DJI Assistant 2 go, that sounds like either a problem with the USB cable or with the computer to which you're connecting the devices. Try a different cable and / or a different USB port on the computer.
2017-7-25
dronist
United Arab Emirates
Make sure no dents, bugs, scratches are present on the props and try again. Try replacing the props and see if the issue is fixed. Also make sure you don't take off from concrete slab or next to metal. One time it happened to me took off from my walkaway and when I took off it start shaking like a brazilian dancer...
2017-7-25
DJI Thor
Flight distance : 13602 ft
Like advice was given above, please check the propellers to see if there are any damages. Please calibrate the IMU after powering on the drone, and then fly it up to 2.5 meters in a benign GPS signal environment.
Please keep us updated if the problem persists, thank you.
2017-7-26
Angelo26
Flight distance : 799718 ft
Austria
Check if "propeller cage"-option is on ! Switsch it off when ON
2017-7-26
guy scott
The vibration has stopped on the drone thank you to all that helped. but the dji assistent 2 itn't reconising my drone i have tryied 2 differnt comuters, all th usb slots and 6 differnt cables.
2017-7-26
