sya
Russia
Hello,
You may connect only X3/X5 series/XT/Z3 via this adapter: https://store.dji.com/product/ma ... al-mounting-bracket
And you may connect Z30 with this adapter (as you have done, I guess): https://www.adorama.com/djiz30gam600.html
You cannot connect X4S, X5S, and X7 because they do not have processing unit inside. This processing unit has been moved on to the drone (Inspire 2 and Matrice 200 series) therefore these cameras are compatible only with these drones.
Also, Inspire 2 and Matrice 200 series are compatible with Z30 (natively via the 80-pin V2 connector) and XT (via adapter due to XT has the V1 20-pin connector). Other 20-pin-V1-connector gimbals (X3/Z3, X5 series) might be connected to these drones with V1-to-V2 adapter (https://www.adorama.com/djimt200pt08.html) but they are not supported in DJI Go 4, I guess. |
