Spark Dronie
2319 12 2017-7-26
Visualkaos
Flight distance : 755988 ft
Has anyone had success with Dronie on the lastest update?  Im on IOS and Dronie doesnt appear to be ascending.  I set it to 10M and it went way past that and didnt gain altitude.  Everything is on the lastest firmware and Go4 app.  Thanks
2017-7-26
Dirk52
Flight distance : 232995 ft
Dronie works for me.. but the altitude is more gained at the end. So it not directly proportional, more of a curve to speak in graphs.But the record video gesture doesn’t work for me ...
2017-7-26
Visualkaos
Dirk52 Posted at 2017-7-26 10:36
Thanks for the response.  Are you using IOS or android?
2017-7-26
Dirk52
Visualkaos Posted at 2017-7-26 11:10
iOS, phone only, no RC.
2017-7-26
Mimus
Flight distance : 284770 ft
what did you set your dronie to?? 40m?  I set mine to 10M and almost no gain of altitude and it went 45m before i stopped it as it would have kept going.
2017-7-26
Dirk52
Mimus Posted at 2017-7-26 12:47
Set it to 20m.
Stopped after 20m, gained 2m height.
2017-7-26
Visualkaos
Dirk52 Posted at 2017-7-26 13:05
Set it to 20m.
I tried it multiple times at 10M and had to stop it at 30m and it didn't gain any altitude.
2017-7-26
DJI Diana
Flight distance : 2408 ft
Could you please refer to the video below to export the flight data and black box data for analysis? Then, upload both files to Dropbox and post the link here, thanks.
2017-7-26
Dirk52
Visualkaos Posted at 2017-7-26 15:53
Maybe I found the problem... do you click GO after you set the distance or do you click back? Maybe the Go App doesn't use the new value when you click back instead of GO. (This is just speculation)
I click:
Flightmodes
Quickshots
Select the object
Click dronie
Click donie again
Set distance
Click GO
(no back after changing the distance)
Works for me great. But like I said, the altitude is gained more at the end.
Maybe this will help:
2017-7-26
JP Santos
Flight distance : 116929 ft
Portugal
Same here! set Dronie to 20M and he flew away. Had to stop it at 35M before it disconnects. Ios user (iphone 7). The helix has teh same problem. He just fly away, not responding my distance input on the app.
2017-7-27
Visualkaos
JP Santos Posted at 2017-7-27 08:29
Thats the same with me. Its just not a usable tool at this point
2017-7-27
antjohns
Switzerland
I tried dronie mode  without setting any distance (I was not aware about clicking Dronie again), Spark gained distance to about 40 m and it did not return to me , instead was still in the top distance. I did not have any clue how to make it come back, I used some controls in hurry and messed up and it started to RTH at the same position instead of coming back towards me, luckily I managed to go to stick mode and drove it back to me.... Anyone faced this before, Can we force Spark to come back ?
2017-7-28
E916
Flight distance : 3478 ft
Has there been a solution posted to this issue?  I have distance set to 10 M, and the Spark ignores it...  I stopped it at about 35 M before it ran itself into a tree branch.
2018-5-19
