deano
I found this quote on this forum, is it correct and hence the issue I have?
*Note to new Phantom 2 Vision+ owners, or anyone thinking about getting one*: They are great, don't get me wrong, but as of this date (Nov 20, 2014) the manual that comes with them or is accessible online hasn't been updated since the Phantom 1. If you get a new P2V+, and the remote control has its own, rechargeable LIPO battery built into it (instead of the earlier version, which uses 4-AA batteries), there's something you need to know to connect it to your computer in order to use the Vision Assistant software which calibrates and can re-configure the controller. The current manuals (Pg 47) say to connect the controller directly to the computer using the supplied micro-USB cable. WRONG.
Here's what you need to do:
0. Be sure the Vision Assistant software and the DJI Driver (for WIN or MAC) are installed on your computer.
1. Use the supplied micro-USB cable to connect your computer to the port in the front of the quadcopter (under the little flap).
2. Turn on the controller.
3. Remove the gimbal clamp and lens cap from the camera.
4. Activate the battery in the quadcopter.
Once the quadcopter is on, the controller is on, and the quadcopter is connected to the computer via the micro-USB cable, THEN you'll be able to start the DJI Vision Phantom 2 Vision Assistant software and perform calibrations, and/or switch from the default "Phantom" mode to the more advanced "NAZA-M" mode, make configuration changes, etc |
