Even after todays firmare update to fix maps, I still have none
1197 10 2017-8-4
dewein
Flight distance : 157746 ft
First...  Acquiring Offline City List and then I get Network Unavailable.  I  try entering a search but as soon as I type a letter it says No  Relevant Data Found.   I have a good WiFi signal so does that mean the  network that the RC is trying to connect to for maps is down?
2017-8-4
Rody Almahmoud
hi ... i have the same problem ... i am in Germany and i can not download the maps!
it's just showing me some city names from Japan or china .. i don't know .. but when i am starting to write the name of my country or even my city ... nothing shown!
2017-8-5
dewein
Rody Almahmoud Posted at 2017-8-5 08:29
I don't know how long I'll have them but I finally got them to work by following some of the instructions here: https://phantompilots.com/threads/phantom-4-pro-maps.103639/
2017-8-5
BagoDJIoperator
Flight distance : 1077608 ft
IO eben noticed the flight profile starting to be incorrect, and bucking of the drone to one side when landing.
2017-8-5
DJI Susan
I would recommend you to reset the RC and check again: Settings--system settings--Backup&Reset–Factory data Reset.
2017-8-16
dewein
Bleh!  I spoke too soon or well.... too broadly.  Maps works but without overlay (even when I cache it at home and leave it on until I get to my destination.  As soon as I take off, the overlay changes to a solid green).  I'm definitely returning the P4P+ and will consider the P4P plus a tablet after researching other brands first.  If I don't return, good luck to everybody!
2017-8-16
RMJovo
Flight distance : 1716240 ft
DJI Susan's solution should work for  you, I lose the maps each time I do a update on the P4P+ control, and the Factory Reset restores the maps each time. Also if you are having map problem with the flight log you can delete the state map and reload it. PS I worked with DJI's tech support the first time I had the problem and that was the solution offered to me.
2017-8-16
dewein
RMJovo Posted at 2017-8-16 13:32
I've done "Susan's solution" several times and plan to return the drone this weekend.  I'll give it one last try before I do and report back.  Thanks!
2017-8-17
RMJovo
After you do the reset did you reconnect the wifi and log in?
2017-8-17
dewein
RMJovo Posted at 2017-8-17 15:16
Yessir!  Been through it 4 of 5 times since purchasing it about 3 weeks ago.
2017-8-19
RMJovo
1. On the top of the startup screen the last button on the far right that looks like a map with a pin drop in it, do you have any Country's listed like North and Central America followed by South America then Europe? Yes/No. Return to the Start up screen.
2.  Back On the startup screen,  In the bottom left corner open what would be the map page (you may just have a gray screen)  start to pinch your finger in on the screen like you wood to zoom out on a touch screen you may have to do pinch in 10 to 15 times is there a map of the US that comes into view?
2017-8-19
