solentlife
Flight distance : 1087530 ft
Latvia
This seems to be becoming a common complaint ... is it just more new owners or is it something else ?
First question ...
When the AC flew away - did you still have video link and your phone / tablet screen displaying position / flight path ? If it did - could you not then follow that to find the possible last resting place of your P3 ?
Do you have cached video on your phone / tablet in GO that shows the flight ?
As L says - upload flight log to get more data and what went wrong ..
But initially as I and others have done - you should use the info you had on screen to find that last known position. If your phone / tablet has GPS of its own - then that could have led you to the last known position ... but trouble is - once you switch off then on-screen info is basically lost. You then use the cached log info along with video to retrace the flight path. Plus of course the log will say what modes / actions occurred ...
The 'fly-ways' on take off / lost signal were sometimes found with earlier Go / FW where Home Point was improperly made - but that glitch has been pretty well sorted. Therefore unless you have old FW / Go - its' likely error in use of the gear.
Was right hand top switch FULLY up in P-GPS position ? If not then with ATTI mode - if you are not used to it will let wind / weather drift her away from you ... as GPS positioning will not assist you.
Was Home Point recorded and correct ? Voice should say Home Point recorded and a quick look at the map in bottom corner should show an H at your spot ...
Was there any warning before take-off ? Compass, Signal, anything at all ?
What were weather conditions like ? Light, moderate or strong winds ? Did the P3 go if in direction of the wind or another direction ?
It really then comes down to looking at as much evidence as possible to try and determine what went wrong. But first ... and this is where any one new to the game will not realise - DON'T switch off tablet or phone ... it just may have that last position on screen ... I am just editing my 'infamous' Go for a swim P3S video to show the use of on-screen position to find the model ... it will be uploaded shortly.
Nigel |
