Agent7837
Hi. My drone was kept in his box for the last 2 week following many error occured (i.e. ESC, Compass, Battery, Lost video signal ...etc, since I update to the new and the last version of the firmware P3P_FW_V01.11.0020.bin. I than try to re-install the firmware 1.9.2 in the RC which is part in this last update (Remote Controler) but was unable to do so. Many messages on DJI Forum were saying to try a different USB stick or/and micro sd card but nothing was working. But I think I found the solution. I want to share with you folks today that I was able to re-instal the new firmware version 1.9.2 in the RC and everything came back normal with just 1 error messge when ready to fly, showed there was no GPS signal but this warning desepears few seconds later while having 15 satellites linked to my drone. When come the time to start the drone (motors), everything went very good (finally). Connection between the drone and the remote is not a problem now. Before I was able to make them in connection but while trying to strat the drone, nothing was happening and after turning drone and remote On & Off a few times, I was able to start the motors and fly but there was alot of messages poping up into the screen of my iphone. This was frustrating without knowing what was going on with this new firmware apparently being updated in the P3P (Phantone 3 Professional) and my RC (Remote Control). Since few days, I was trying to re-install the firmeware 1.9.2 in the RC but after 5 minutes the light on the RC was still red (its suppose to be blue when updating with bips) and the update (P3P_FW_V01.11.0020.bin in my sd card which was in the usb stick lodged behind the RC in the usb slot) was ignored.
Here's what I did today step by step: I first connect my iphone to my RC. As soon I log the apps DJI Go, put your finguer at the top right corner for 5 second and release. You will than see What version you have and be able to choice a lower version to downgrade the firmware. Try 1.8.0 but you will be probably not able to download it. If so, try the next one version 1.6.0 and it should download. After install the version 1.6.0. As soon you will hit ''install'', the RC light will turn blue meaning it is uploading and install the update your choose. For me when I reach 97% complete, it failed but I hit again install and the process started again and updated successful at 100%, showing at the end ''please do a restart of your RC and I did. As soon you will do a restart, a prompt message will indicate that a new firmware version is requered. From there, use the link ''download'' and let the update install when prompt to do so. It will again ask you to do a restart. DO it, turn on your drone and everything should work finally fine like it was before ! That what happening with me today. I use my drone as normaly all the day. I didn't put any picture to show you how to do it but let me know if my step are not clear enought. Whish you the same luck !!! Let me know if this work with you.
