RedHotPoker
Flight distance : 165105 ft
Eric ncfwa Posted at 2017-9-5 17:17
Hi RedHotPoker,
I was using auto land on my P4P, don't anymore because of the hard landings, I was sure this was not right, my P3S lands like a feather on auto land, do you think there may be a bug or something causing this on the P4P?
Regards
No certainly not a firmware bug, as my Phantom 3 Pro demonstrated a hard Auto Landing touchdown, far too firm, for my liking.
I suppose if you had a soft foam, sponge like material covering a landing pad, it would be perfect. ;-)
In some ways, I'd wish the initial gimbal calibration, upon starting up the aircraft, could be done right after takeoff. Rather than that routine sequence, which drags the camera front element across any uneven surfaces, directly below the drone. I have purchased a flower petal lens hood, that adds more length to the camera lens section, and so, it must be applied, after the completion of my gimbal calibration, once the camera has returned to its front facing direction. Longer legs would benefit here.
RedHotPoker |
