Picking Up Compass Problems On the Ground
872 20 2017-8-10
hallmark007
Flight distance : 9827923 ft
Always be careful where you take off from there are many hazards on the ground, take a look at this video, same will apply to spark.
2017-8-10
Mimus
Flight distance : 284770 ft
I had a similar issue like this with the spark. I was next to a fountain downtown chicago next to the river. As soon as i took off it got a compass error and started drifting so i recalibrated same issue. Decided not to fly it.
2017-8-10
hallmark007
Mimus Posted at 2017-8-10 08:15
If you get a message to move spark or calibrate, never try to calibrate always move to another location free of all magnetic interference. Calibrating compass in an area where there is metal objects rebar concrete cars etc will almost certainly lead to bad calibration.
2017-8-10
Mimus
hallmark007 Posted at 2017-8-10 08:28
This was when i was new to flying. At least i was smart enough not to fly it
2017-8-10
hallmark007
Mimus Posted at 2017-8-10 08:38
Good job Mimus, it's a learning curve for us all....
2017-8-10
Thor1
Flight distance : 196837 ft
excellent advice.
Hallmark007, would you happen to know about how far away i should be from any metal, ie: cars, power lines, etc..., when i calibrate? i never calibrate unless the app tells me to but i would like to know just in case. i could not find it in the manual.
2017-8-10
Rawsome
Flight distance : 230827 ft
Excellent advice, I can trace a few compass errors back to where I calibrated with possible interference.
2017-8-10
hallmark007
Thor1 Posted at 2017-8-10 08:51
excellent advice.
From cars large metal objects rebar concrete 10 metres should be ok, best to remove all jewellery watches and other metal objects and don't forget to keep RC at least 3 metres distance away.
2017-8-10
Mimus
hallmark007 Posted at 2017-8-10 08:46
I wonder if i palm launched , would i have the same problem??
2017-8-10
Thor1
hallmark007 Posted at 2017-8-10 08:59
awesome, thanks!
2017-8-10
hallmark007
Mimus Posted at 2017-8-10 09:01
You shouldn't pick up interference from palm launch, I've heard some say Apple Watch might be a problem but I have one , no problem.
2017-8-10
Mimus
hallmark007 Posted at 2017-8-10 09:14
I think setting it down on that concrete filled with re-bar and what else might be in there can screw with the compass.. hence the error later in flight.  Next time i am there, i will palm launch  and see how it goes. But it wont be for a while probably.
2017-8-10
rockmsu
Flight distance : 90804 ft
Beyond the alerts, how can you tell if there is strong interference with the compass? Sometimes the compass error passes and you don't really realize til your midflight which can result in a scary flight. Is there a way to check if you're in a comfort zone prior to launching?
2017-8-10
Jeff7577
Flight distance : 1916821 ft
Look at the direction the map shows his drone is pointing.
2017-8-10
hallmark007
rockmsu Posted at 2017-8-10 09:31
This link might help you
https://forum.dji.com/forum.php? ... &fromuid=260008
2017-8-10
rockmsu
Yes I've read this and follow those pre-flight procedures, but sounds like from a number of folks including that it happened to me once that these things can arise mid flight. Not sure if there's a better graph or histogram of interference in the area to avoid these calibration issues happening mid flight.
2017-8-10
hallmark007
rockmsu Posted at 2017-8-10 10:21
What happens during flight can sometimes be attributed to what happens preflight, if something happens at high altitude, then at least you will know you did everything to avoid, there is not much more you can do,
2017-8-10
PascalG
Flight distance : 274327 ft
Bahamas
I wouldn't be surprised if the drone didn't get interference from the the ship transmitters:  two radars, vhf, satcoms, AIS, cellular modems with external antennas, routers, etc  that's a lot of stuff at close range
2017-8-10
hallmark007
PascalG Posted at 2017-8-10 10:38
Yes there is a lot going on, but if you look at video you will notice compass triangle is backwards right from take off leading pilot to think he picked this up from the ground.
2017-8-10
DJI Thor
Flight distance : 13602 ft
Thanks for sharing. If the aircraft has not taken off and the compass readings are abnormal. It is recommended to power off the aircraft, calibrate the compass in a different place and then fly again.
Besides, we recommend taking off as far as possible after powering on and self-checking finished, long time of standing on the ground might cause compass interference.
Radio transmission towers, power lines, base stations, electromagnetic interference devices, and large deposits of magnetic metal might cause compass error. As we could see there is a bridge near around, it might be the source of interference. We would suggest changing another open wide to fly.
2017-8-10
DJI Thor
This issue might occur because the aircraft is flying in a place where the compass cannot detect the interference correctly. We suggest landing the drone manually if possible and change another place to fly.
2017-8-10
