Air encoder error (0x20)
8547 12 2017-8-10
Gustave
Flight distance : 138 ft
It's been a subject before but I do start a new thread about this error.
I have a brand new Phantom 4 Pro with a GL300F remote controller. I only flew it once (for experiencing if it worked). I have been flying DJI drones since the Phantom 2.
After the flight I did the suggested firmware upgrade and did not fly until now, on holiday.
I noticed that the DJI Go 4 app showed an error in the AC: Air encoder error (0x20) and a "No image transmission signal" in the red bar.
I sorted out the possible SD Card issue but I do not think that is a problem.
I tried to "Factory reset" the bird in the DJI Assistant 2 application on  my Windows 10 Pro PC but that does not work. I also tried to reinstall the firmware from the same app but I do not now if that succeeded or not. The progress bar stopped at 15% and after an hour I disconnected and restarted the AC to find that the fw was still there.
App                      version 4.1.5
Aircraft                 version 01.04.0602
Remote Controller  version 01.04.01.00
Flight database      version 01.00.01.04
App database        version 01.00.01.04
What can I do about this? Is it a software/firmware issue or is it hardware? (It worked before the fw upgrade).
When the AC is connected to the DJI Assistant 2 on my PC, the connection is intermittently disconnected and connected (every 20 or 30 seconds). Does that indicate a hardware issue?
The Aircraft Status LED (in between the micro USB port and the SD Card slot) flickers from green to red to orange.
Thanks for helping out.
2017-8-10
BagoDJIoperator
Flight distance : 1077608 ft
Try and download the Firmware for the AC manually on the SD card and see if that works.
2017-8-10
Gustave
BagoDJIoperator Posted at 2017-8-10 06:50
Thanks for replying.
Where can I download the P4P firmware? It's not on the DJI site. Anyway not in a straightforward way.
2017-8-11
BagoDJIoperator
Gustave Posted at 2017-8-11 03:47
I think when you go to the DJI Assistant on your computer you have the option to download locally and use the SD to load it.
UPDATE:
I dont think you can redo your firmware, I was thinking about the RC.
2017-8-11
DJI Susan
I would recommend you to refresh the aircraft firmware via DJI Assistant 2 for several times.
If still no helps, please contact our support team via support.eu@dji.com to send it in for diagnosis.
2017-8-12
peter-a
Flight distance : 2228 ft
I have exactly the same set of problems.  Did you get a resolution?
2017-10-26
peter-a
Firmware refresh didn't help.  I notice that the green-orange-red now persists for many minutes.  Then finally becomes green and video transmission works again.  Spoke with German DJI tech who said it could be hardware but so far I've tried to see if I could resolve it myself.  Any other suggestions welcome,.
2017-10-26
VWStevens
Flight distance : 25630 ft
Did you ever resolve this as I have exactly the same problem
2018-5-12
Fabio Cavalcant
Flight distance : 7379 ft
Brazil
I have the same problem. My Drone is a Pro Ghost 4. He calls and takes so long to appear in the picture. All a black screen with a message. AIR ENCODER ERROR (0x20). If the problem persists contact DJI support.
After 3 minutes the image appears and the error disappears. I'm in Brazil, Rio de Janeiro and it seems that there is no support from DJI here. I'm disappointed.
2018-6-3
djiuser_h4sHT2BoILYV
I have a problems in dji phantom 4 pro
2018-8-16
My drone was crashed while flying due to low battery in to the water I found after 3 hours after that I cleaned and dried it is getting on but showing error. 1.camera sensor error, 2.aircraft error (0*20),3.esc status error please help me anyone
2018-8-16
polloman
Chile
error 0x20   ( controladora de vuelo ).
2020-6-15
djiuser_6Ytu6oxDYRCf
Russia
good evening, did you somehow solve this problem, since I had exactly the same one, can you please help me with it?
2022-8-19
