Bringing Spark to Solar Eclipse Event
1724 26 2017-8-10
Maxi3D
Flight distance : 307621 ft
I am deciding whether or not to bring my Spark to the Aug 21st Solar Eclipse. I don't think it will fly high enough to see the moon shadow moving across and Spark will not stay in the air long enough to film the darkening of the sky. I could fly it up and park it there during the full solar occultation. Any idea on camera settings I should use and how best to employ the Spark during Solar Eclipse?
2017-8-10
Oracle Miata
Flight distance : 3759829 ft
This will cause problems for you...  and your spark.  To much significant interference during the event.
2017-8-10
Oracle Miata
With that being said it was something that I was considering as well...
2017-8-10
Maxi3D
Oracle Miata Posted at 2017-8-10 06:06
What kinds of significant signal interference are you referring to?
2017-8-10
ThirdEyeFlyin'
Flight distance : 162444 ft
Don't really see the point as the drone is an aerial camera platform. To observe the eclipse via this platform means that  the shot will be oblique in the extreme and you could get the same result standing on a hilltop. I'm curious though what the effect might be.
2017-8-10
pashas_dad
Flight distance : 982723 ft
I was considering the same but consider how much of your attention is taken up by flying the aircraft.  You will miss a truly remarkable event.
I'm leaving it home!
2017-8-10
Maxi3D
I guess I won't be using my Spark for the Eclipse, but I will leave it in my trunk just in case. With my luck, it will probably be pouring rain on the spot I have chosen on the 21st.
2017-8-10
Charles Adams
Flight distance : 3821312 ft
By the vary nature of the process, the spark won't be able to see the moon occlude the sun.  But the spark could observe the ground effects (the darkening at mid day).  That would be pretty cool.
The spark could show a view of all the people looking up :-)
2017-8-10
LouisP
Flight distance : 41952 ft
Not to shoot the eclipse.. but from high up you might see the moon's shadow moving across the earth.. and good shots of people looking up... just think... some of them will probably be damaging their eyes beyond repair while you are recording them.
2017-8-10
Charles Adams
LouisP Posted at 2017-8-10 12:58
Probably not at 400 feet.  The view would probably need to be higher (not condoning or condemning anything, and not judging).
2017-8-10
DJI Thor
Flight distance : 13602 ft
For camera settings, we suggest the camera not facing the sun directly to prevent the solar burning the camera. You can add an ND Filter onto the camera.
2017-8-15
Tviscomi
Flight distance : 106886 ft
Maxi3D Posted at 2017-8-10 06:21
Yes, I'd like to know the answer to this too...
2017-8-15
mtnlandpix
DJI Thor Posted at 2017-8-15 01:44
You should actually use a Solar filter if you intend to photograph the actual eclipse.  Most ND filters are not enough to protect the camera sensor.  Although you can remove the filter while you in totality, if you are fortunate enough to be in that locale.
2017-8-15
Prezmc
Tviscomi Posted at 2017-8-15 04:51
Ditto on this. What interference?
2017-8-15
Hankmeister
Flight distance : 19465 ft
I witnessed the last total eclipse in the USA back in Feb 1979 in Montana..it was awesome!! I bought the Spark especially for the 2017 eclipse. The most amazing thing I remember is not looking at the sun/moon, but looking at the Doom and End of the World approaching from the west!! I hope to be on high ground and have the Spark fly high above me to record the Doom approaching. When totality occurs I hope to fly high above and record panorama  of the 360 deg sunset/sunrise. Then I hope to record looking to the West, of Goodness and Light approaching as if Mother nature had answered my prayers and saved mankind. Hoping of good weather.
2017-8-15
method007
Flight distance : 110449 ft
I hope that most people realize that pointing any lens directly at the sun is a bad idea and could literally set your camera on fire.
2017-8-15
Oracle Miata
Prezmc Posted at 2017-8-15 05:50
Fly with caution, there will be significant satellite interference.  This is what I've been told.  The event is also suppose to cause several power outages as well.  It appears by the response from one of the moderators, that they don't appear too concerned.
2017-8-15
JoeCec
Flight distance : 3491430 ft
The sun will not emit any more solar radiation than any other day. It's just the moon passing in front of it. However, the radiation of the sun will still be present causing Cortical blindness if you look up during the full eclipse. So... don't look at the sun or moon..... I would fly.... Just sayin...
2017-8-15
Maxi3D
method007 Posted at 2017-8-15 11:11
A flaming Spark dropping out of the eclipsing sky. Sounds like a Wagnerian opera.
2017-8-15
Hankmeister
you will see the moon shadow darkening the sky way before the total eclipse...awesome. Panorama of 360 deg sunset/sunrise during totality. Use your Spark for this amazing event.
2017-8-15
Hankmeister
ThirdEyeFlyin' Posted at 2017-8-10 06:24
Observing the eclipse is a lot more than looking at the moon and sun. Having height makes the horizon further away to see the darkening of the sky (and lightning of the sky) at a distance
2017-8-15
Hankmeister
pashas_dad Posted at 2017-8-10 06:24
Don't leave it at home. the main event is the approach of the shadow which you can see at a distance film it!
2017-8-15
Hankmeister
Maxi3D Posted at 2017-8-10 11:25
hopefully we will both have a clear sky. Get that Spark out of the trunk and film the approaching shadow and film the panorama at height of the 360 deg sunset/sunrise
2017-8-15
Hankmeister
Charles Adams Posted at 2017-8-10 12:41
A lot more than that! The approaching shadow will seem like the end of the world is coming and 360 deg sunrise sunset is amazing.
2017-8-15
Hankmeister
Charles Adams Posted at 2017-8-10 13:27
You will see the shadow approaching not just the shadow on the ground, but the sky itself above the ground will be dark. I have seen it ....the most amazing the I have ever seen
2017-8-15
method007
Maxi3D Posted at 2017-8-15 14:30
Based on other responses in this thread, I'm almost certain we will see that post on 8/22.
2017-8-16
djiuser_gZqopef
We had spectacular results with the Spark during totality.  The video posted to YouTube is entitled, appropriately enough, "The best DJI Spark 2017 total eclipse video."
Enjoy!  Mike from Kauai
2017-9-25
