Wellsi
Flight distance : 8330187 ft
MARSAN Posted at 2017-8-10 07:54
1) Can you see any obvious physical damage?
2) Does the camera easily go to portrait mode and back?
3) The gimbal is attached by a couple of elastics, are they all intact?
Hi all
Thanks for the replies. Marsan, to answer those points:
1) Can you see any obvious physical damage? No; none at all.
2) Does the camera easily go to portrait mode and back? Yes;
3) The gimbal is attached by a couple of elastics, are they all intact? Yes; both elastics fitted as usual
4) Can you move the gimbal freely by hand without knocking against anything? Yes; it can be moved in every direction with no rubbing or knocking at all
5) Are all the electric cables intact? Yes
6) Is there any dirt (dead/live insect?) blocking the gimbal's movement? No.
I've also tried resetting the gimbal settings to factory settings and as said, when it's flying, I can use the roll wheel to move it up and down fine. However when it flies sideways, the gimbal hopelessly fails to stay level and you get a real sloping horizon (40' or more) until you stop flying sideways and the Mavic levels out.
So I'm able tt use around 1/4 of the video I shoot
And of course, I'm a bit worriied about the knocking it does on power up as it cycles vertically through its full cycle, from end stop to end stop....
I can see this having to go in for repair, but it seems daft as there is no apparent damage whatsoever and it literally seems just disorientated and confused....
Ian
